What should I do???
Old Feb 20, 2004 | 06:02 PM
tweakdsm's Avatar
boost gauge - see if you got boost leak...
Old Feb 20, 2004 | 06:06 PM
Az3ar's Avatar
hey guys, about gas i just moved to CA and started using that ****ty gas. although i did not feel almost any power loss i know i did loss couple whp. anyways, their is a gas stations right next to my house called G&B it looks good and new so i started using it because the y are like 15c cheaper do you guys have any thoughts about this gas station.
Old Feb 20, 2004 | 06:57 PM
tweakdsm's Avatar
lol, MOBIL 1 OR DAMN - Shell ok ? ....
Old Feb 21, 2004 | 02:51 PM
bluevilevo8's Avatar
Well, I just installed the gauge, and I hit 1.4 bar consistently. I must be going out of my mind, as that is over 19.5 psi. I idle at 450mmhg (or 17.x inhg) which is perfect as well. Maybe I'm crazy?
Old Feb 21, 2004 | 03:27 PM
dpardo's Avatar
I would take mine to a reputable EVO 8 performance shop and have them take a look at it.
Az3ar,
I would definitely avoid the no-brand-name gas stations.
Chevron, Mobil, Unocal 76, or Shell is all I use (here in SoCal anyway).
Old Feb 23, 2004 | 07:28 PM
Capt_Crunch's Avatar
Keep in mind, Greddy boost gauges do not run exactly in bars, but in kgf/cm2. Try this link for conversions.
http://www.convert-me.com/en/
Also, have your dealer, check the voltage on your boost solenoid, they have been known to go out.
Good luck.
Old Feb 23, 2004 | 07:35 PM
Good luck.
Yeah, but the two measurements are practically the same.
I'll do the solenoid thing, but I doubt I'd be getting full boost with a problem like that.
