oil dip stick keeps popping off..
Old Jun 29, 2013 | 12:47 AM
babaz7's Avatar
i have recently build a 2.1l engine, and the dip stick keeps popping off at 25-30 psi spilling all the oil on the intake manifold and the down pipe, what cud be the reason?
and how do i solve this problem?
Old Jun 29, 2013 | 01:41 AM
MR. EVO MR's Avatar
Crimp the top of the tube
Old Jun 29, 2013 | 02:31 AM
EVOn9ne's Avatar
you need to run an oil catch can
https://www.evolutionm.net/forums/ev...re-issues.html
Old Jun 29, 2013 | 10:09 AM
cmspaz's Avatar
This is a bandaid fix, but here you go:
http://www.evomn.net/forums/showthre...ping-out-Fix-t
I have since (and when my head comes off next week, will continue to) added crankcase venting to relieve the real issue. The Good 'ol spring has stayed, though. It's a good insurance measure.
Old Jun 29, 2013 | 10:38 AM
uhhhson's Avatar
Originally Posted by EVOn9ne
what he said^
Old Jun 29, 2013 | 11:00 AM
EvoIXPilot's Avatar
Can't you zip tied it to something? That's what I did when go WOT for a tune
Old Jun 29, 2013 | 11:44 AM
asu11's Avatar
Yeah you need to relieve crankcase pressure first as others have stated.
Old Jun 30, 2013 | 02:01 AM
babaz7's Avatar
so if i run a oil catch can and my problem will be solved?
isnt there a easier way to do it?
and is there a problem with my new block that it has so much oil pressure issues?
Old Jun 30, 2013 | 12:18 PM
RSGuy's Avatar
You really should read this:
http://www.dsmtuners.com/forums/arti...cv-system.html
Old Jun 30, 2013 | 05:50 PM
xXevo8RavenXx's Avatar
compression test it please or the pcv
Old Jun 30, 2013 | 07:18 PM
hiboost2.0's Avatar
No, and they're not oil pressure issues, it's compression from the combustion chamber sneaking past the piston rings into the oil pan area.
Old Jun 30, 2013 | 07:28 PM
^ exactly why i said compression test is your friend
Old Jul 1, 2013 | 09:46 PM
EVOn9ne's Avatar
I hope non synthetic was used during break in , sounds like maybe the rings didn't seat properly and now your having blow by issues. Who built this engine?
Old Jul 1, 2013 | 10:06 PM
AKW89's Avatar
Exactly what I was thinking... What was the break in procedure? What is the mileage on the motor. I hope you didn't jump right into 20+ psi straight after your build.
Old Jul 2, 2013 | 03:45 PM
slimjim1804's Avatar
Excess crankcase pressure. Revise your PCV setup, and perform a compression test. any oil seeping past crankshaft seals?
Posted from Evolutionm.net App for Android
