ecu codes, help
Old Jul 2, 2013 | 11:48 AM
rbmxer's Avatar
ecu codes, help
Ran my check engines and this is what popped up:
P0037 - powertrain - HO2S heater control circuit
P0401 - powertrain - exhaust gas recirculation flow insufficient detected
P0325 - powertrain - knock sensor circuit 1
Please define...thanks
Old Jul 2, 2013 | 11:46 PM
rbmxer's Avatar
Bump
Old Jul 3, 2013 | 02:46 PM
rbmxer's Avatar
Help
Old Jul 3, 2013 | 04:00 PM
TeachersEvo's Avatar
1st code- secondary (downstream, in exhaust, not housing off turbo) O2 sensor heating element went out, won't heat up correctly. Tested over several cycles. 02 sensor is probably bad.
2nd code- the exhaust gas recirc system has a leak somewhere or the diaphram on the EGR valve itself is stuck shut (or blocked off, or ect)
3rd code- engine has detected pre-ignition from low octane fuel, inappropriate mixture, or a variety of other reasons (overboost, not tuned for mods... ect.)
Old Jul 3, 2013 | 04:03 PM
also, searching each of those codes in google will yeild plenty of results:
http://lmgtfy.com/?q=lancer+evolutio...ontrol+circuit
Old Jul 5, 2013 | 09:12 AM
rbmxer's Avatar
Alight thanks alot, preciate it
CT9A PR
Oct 29, 2015 06:44 PM
mshilto89
13
Mar 24, 2015 02:45 PM
joe52
Dec 31, 2014 04:57 AM
Der König
Aug 20, 2014 01:40 PM
Stockie
May 9, 2014 09:20 AM
