Tell tale signs of knock?
Old Jul 3, 2013 | 04:02 AM
Viegasjuice's Avatar
Are there any sure signs your engines knocking? Apart from logging, is there my way to know? Was wondering how loud lifter tick should be..I have a buschur TBE, no muffler AND catless with gsc s2 cams and I can hear the ticking sound pretty easily from outside the car. It's much more pronounced on startup than any other time. Thanks in advance
Old Jul 3, 2013 | 02:23 PM
JayB12's Avatar
I don't really know which type of knock your looking for? Pre-ignition knock or a rod-knock type sound.
If you think it's an internal engine problem, check in your oil/oil filter for metal debris.
The spark plug would show signs of detonation, if it were pre-ignition knock.
A video of the sound would help.
Old Jul 3, 2013 | 02:38 PM
4RETECH's Avatar
When you had the cams installed did you bleed the lifters?
I have seen guys not bleed them and the lifters break internally, only a few, but it does create a loud ticking upon startup because they don't retain the amount of oil they should on start up.
Old Jul 3, 2013 | 02:39 PM
Raybrant's Avatar
If you grab one of those diagnostic tools that plug into your OBD2 port they usually have knock detection from your knock sensor.
Old Jul 3, 2013 | 06:06 PM
I have a feeling that's the problem. They were installed by previous owner.
Old Jul 3, 2013 | 06:49 PM
theoszarz14's Avatar
I believe I have come across the same situation! Sorry not trying to jack your thread, anyone have a decent fix?
Old Jul 3, 2013 | 07:35 PM
Keep I'm mind Evos are loud and valve tick is normal. I'm just making sure mine is normal.
Old Jul 3, 2013 | 08:59 PM
4RETECH's Avatar
If anything, try to load a vid.
Old Jul 3, 2013 | 09:08 PM
I will and post it up
Old Jul 3, 2013 | 09:45 PM
pacent's Avatar
If your car is knocking enough for the ecu to pull timing, you can feel your car not pull as hard as it should. Other than that, you can log it, or get a set of these:
http://www.linkecu.com/products/Tuni.../g4-knockblock
Old Jul 3, 2013 | 09:48 PM
BEKevo's Avatar
Do what others have mentioned and make sure to verify you have good oil pressure. Really, really low idle rpm will have low OP. But unless your OP light hasn't flickered or came on, you should be good. Just throwing ideas out there..
Let us know what you find.
Old Jul 3, 2013 | 09:51 PM
Oil pressure is beautiful. 15ish idle. Perfect cruise.
Old Jul 3, 2013 | 10:10 PM
BEKevo's Avatar
Nice.. You can check that off for a possible culprit. Process of elimination.
Old Jul 3, 2013 | 10:20 PM
I'm mostly just being paranoid as is is my first turbo car. I need to order a tactrix cable and start logging tweeking. I'm new to this stuff.
Old Jul 3, 2013 | 11:37 PM
metazcq's Avatar
