Question for those with over 650whp.
Old Jul 5, 2013 | 03:06 PM
IXmr321's Avatar
Forgive this newb sounding question. What size exhaust are you guys running? I just ordered a built bottom end and a 6766 turbo kit and I'm wondering if I should buy a 3.5" exhaust to replace my 3" currently on the car. I've built several cars but nothing as high power as I am shooting for on this car, and I'm just curious what the power threshold is when a 3" starts to hold you back. Thanks.
Old Jul 5, 2013 | 04:13 PM
SmurfZilla's Avatar
3 inch Tomei Ti. Its been fine thus far.
Old Jul 6, 2013 | 08:11 AM
EvoJoeIX's Avatar
3 inch is all you need
I mean buschurs 9 second street cars run 3" exhaust, thats proof that 3" is enough
Old Jul 10, 2013 | 07:53 PM
evosnstuff's Avatar
well i know you dont want to hear anything from me cause i make a mere 405whp, but i run 2.5 and 2.5 is solid for like up to 500-550 hp so i assume your good for up to 7-8 without bottlenecking, remember back pressure is your friend
Old Jul 10, 2013 | 07:58 PM
SaulHudson's Avatar
It sure is not.
https://www.evolutionm.net/forums/ve...ure-plate.html
Old Jul 10, 2013 | 08:28 PM
gpfury86's Avatar
well i know you dont want to hear anything from me cause i make a mere 405whp, but i run 2.5 and 2.5 is solid for like up to 500-550 hp so i assume your good for up to 7-8 without bottlenecking, remember back pressure is your enemy
Fixed it
Old Jul 10, 2013 | 09:30 PM
Bramage_Dained's Avatar
My car made 900 with a 3". Would a bigger exhaust have helped? Probably. If you're that into it you could dump out the hood or passenger side of the bumper.
As it was I was spark limited, not anything else.
Old Jul 10, 2013 | 09:42 PM
gpfury86's Avatar
bit off topic lol with what ignition system?
Old Jul 10, 2013 | 11:15 PM
Svendiesel's Avatar
Just because Buschur ran a 9 with a 3" exhaust does NOT mean it is all you need. Thats garbage. You can run a 9 with a massive ***** on the front of your car and say thats why you ran the 9, because the ***** cut thru the wind. Doesnt mean its the way to go though.
On the 6766 youre running it depends what the exhaust outlet size is of the hot side. If youre running a T3 .82, its a 2.5" outlet, so youd be ok with a 3" exhaust. If youre on a vband outlet, its a 3", so again a 3" exhaust is still ok because there is no step-down restriction. A T4 is 3-5/8in outlet. Here is where you would want a larger size exhaust. 3.5in is technically still small for 3-5/8ths by 1/8th of an inch. A turbo system is essentially one big restriction, but you want to minimize restriction.
The bigger the exhaust the better, but in most cases a 3" will do just fine.
Old Jul 10, 2013 | 11:18 PM
UsafEvo's Avatar
Currently at 678 hp and the 3inch has been fine.
Old Jul 11, 2013 | 07:42 AM
SpoolinUP Cop is what was on my car.
Old Jul 11, 2013 | 12:09 PM
EvoJoeIX's Avatar
I simply provided an example of fast cars on 3" exhaust without rambling on like your post
You seem to fancy ****** though, have fun with that
Old Jul 11, 2013 | 12:58 PM
Svendiesel's Avatar
Well, your example sucked and lacked an actual reason as to why 3" is all you need.
Old Jul 11, 2013 | 10:01 PM
batty200's Avatar
If you are using a wastegate dump a smaller exhaust will work since up to 50% of the exhaust flows out of the wastegate. If you are recirculating I would recommend a larger exhaust.
Old Jul 11, 2013 | 10:17 PM
mrfred's Avatar
lol. your explaination is impeckerable. what a great quote for a sig. and i do fully agree.
