my EVO IX acting up
Old Jul 19, 2013 | 09:32 PM
dayak's Avatar
my EVO IX acting up
i guess my plan to swap turbo is will have to be on hold for now..
first thing first i noticed i have idle problem and would stall when coming to red lights or stop signs and worse with AC on, its been about a week i have to live with the idle problem.
and today this morning its giving me p0340 code which translate to camshaft position sensor, bought a sensor and cleared the code but came back right away and next thing i did swapped the exhaust/intake camshaft sensor and still the same code and the idle still rough and struggling.
the evo will fire up no problem but with idle problem and p0340 engine code. do i have 2 issues or the idle problem caused the p0340?
any hint/possible solution is very welcome and i appreciate it..thank you in advance
Old Jul 20, 2013 | 02:47 AM
Ryan4dc's Avatar
Seeing you have a code reader, does your code reader also show live data? You could watch the rpm and Look for major fluctuations at idle/cruise/free revving. Let's say it glitches to zero intermittently maybe? Check your wires for open breaks/loose connectors(pins backed out of connector)/burns.
Old Jul 20, 2013 | 11:22 AM
dayak's Avatar
shot a video this morning from warming up from the car still carries p0340 code with bad idle as you can see, the exhaust note weird sounding as if i have cam.
Old Jul 20, 2013 | 01:19 PM
Ricoswave's Avatar
That motor sounds pretty bad, not sure if it is a mechanical issue or a bad sensor. It almost sounds like the timing has jumped, and the cam sensor if faulting because it is out of phase?
For your sake I hope I am wrong and its just something stupid. I would yank the timing cover off it and check the marks.
Old Jul 20, 2013 | 02:13 PM
dayak's Avatar
started out with bad idle a week ago, yesterday triggered p0340 code, camshaft position sensor replaced, ground and wires as far as inspection looks good, i think i am looking at crankshaft position sensor thats bad or like you said timing jumped..and yes engine sounds bad at this moment.
Old Jul 21, 2013 | 12:08 AM
Ryan4dc's Avatar
Have you checked your oil level? Maybe the buckets just sound a little loud from my iPhone speaker. Not sure.
Old Jul 21, 2013 | 09:20 AM
dayak's Avatar
Oil level is good
Old Jul 21, 2013 | 11:26 AM
Canadian-Ix's Avatar
Possibly broken lifter?
Old Jul 21, 2013 | 02:05 PM
dayak's Avatar
sounds like head job and big bill to me but anything is possible but will it explain the rough idle and p0340?
im not sure what to do yet, but i am thinking to replace/check crankshaft sensor and check timing
craig05evo
Aug 4, 2014 08:17 AM
Havoc86
Lancer Troubleshooting
24
Mar 31, 2013 09:14 PM
09_Lancer_GTS
Lancer Aftermarket Forced Induction Tech
14
Feb 21, 2011 03:16 PM
binhtran
Dec 18, 2008 12:40 AM
Fitz
Sep 10, 2007 09:00 AM
