Stupid compression question
Old Aug 1, 2013 | 07:24 PM
Viegasjuice's Avatar
Just was curious, for example your compression is 150 across. How much on general should it decrease every 10k miles?
Old Aug 1, 2013 | 10:13 PM
TeachersEvo's Avatar
Zero, is what it should do and what you hope it does. Only time it should go down if something harms the motor.
Over a very long period of time, the engine will wear out on its own causing compression to leak from various places out of the CC but not over 10k miles.
Old Aug 1, 2013 | 11:42 PM
should regular maintanance be the deciding factor? what are main things that cause compression to weaken, is it rod knock?
Old Aug 2, 2013 | 10:22 AM
VWJETTY's Avatar
excessive boost
Old Aug 2, 2013 | 02:41 PM
b00stah0lic's Avatar
Excessive boost, lack of oil, bad cams, etc. There are a lot of things that can cause it, but boost is the most common reason.
Old Aug 2, 2013 | 05:33 PM
Thanks for responses guys. By excessive boost does that mean high boost, boosting all the time for no reason or comvination of both
Old Aug 3, 2013 | 04:14 AM
Combination of both. Know your motor's limits, like how much boost your set up can safely run. If you hit boost 24/7, your engine will wear out significantly faster than if you drive with a lighter foot.
Fhisre
Oct 25, 2014 01:03 PM
DormantBeast
18
Jan 30, 2013 05:23 AM
NRG
Aug 14, 2011 02:12 PM
Enzo1089
56
May 19, 2010 06:25 PM
haseeb
47
Dec 6, 2009 05:36 PM
