lets play guess this sound (video)
Old Aug 13, 2013 | 12:13 PM
Jesussaves1's Avatar
Old Aug 13, 2013 | 12:22 PM
SilverShadow03's Avatar
Did this just start one day or did you do a timing belt change or did someone else do some work lately? Recent cam install?? Oil level check out OK?
More info is needed to help you out....
Old Aug 13, 2013 | 12:40 PM
adam_79_2005's Avatar
sounds like the cams or the cam gears, like the guy above asked, was work done recently to the cams or possible a belt change?
Old Aug 13, 2013 | 01:41 PM
yep had new cam's put in kelford 272. timing belt changed. it started small. was a oil leak in the lower timing belt area. took of the top cover to find my brand new belt was frayed in spots and this noise got so bad and loud i had to pull it over and get a tow. i'm just wondering what it could be so i know what to expect . dont know if it skipped timing but there was oil on the belt pretty bad
I appreciate all of your guy's feedback. i'm very saddened i think God is Punishing me
Old Aug 13, 2013 | 01:49 PM
CtSilver03Evo's Avatar
I would start by pulling your timing cover, line up all your timing marks and see if it all looks right... I really hope for your sake that you didn't jump timing bad.
Old Aug 13, 2013 | 02:03 PM
aggieEVO's Avatar
DIY or did you have a shop do it?
Old Aug 13, 2013 | 02:08 PM
Had a shop do it
joseph143's Avatar
if the belt was frayed on top of the noise i would say in the timing cover... like you crank trigger is bent or the belt tension is so high its burnt the idler pulley bearings
Old Aug 13, 2013 | 02:14 PM
thanks alot for all the advice im gonna take a look at all of you guys opinions .. Love the evom community.
Old Aug 13, 2013 | 02:37 PM
aggieEVO's Avatar
If you just had it done, I'd be on the phone with the shop that did it very quickly.
Good luck, man. That's not a fun situation.
Old Aug 13, 2013 | 02:54 PM
itsmrrizz2you's Avatar
id bring it to the shop. have it towed to prevent further damage
Old Aug 13, 2013 | 02:55 PM
sounds like it could be rod knock but cant tell from the video. could be something like the cam caps are loose or something
Old Aug 19, 2013 | 02:57 PM
Any news?
Old Aug 19, 2013 | 04:34 PM
TeachersEvo's Avatar
sounds like an over tightened belt + fried pulley bearings to me, but hard to tell from the video.
At :05-:06 that is for sure a cricket.
Old Aug 19, 2013 | 04:40 PM
mullen's Avatar
^ what he said. may be overtightened
RA012124
Outlander Sport
56
Apr 9, 2016 03:31 AM
mRVRsport
Outlander Sport
Jun 30, 2015 06:10 PM
pointblink19
Sep 14, 2013 04:55 AM
