Best way to glue PCV valve on Valve cover?
Old Aug 22, 2013 | 06:12 AM
bnr34rb26dett's Avatar
Exclamation Best way to glue PCV valve on Valve cover?
Hello Evom,
I was wondering what people were using for keeping their PCV valve in place on the valve cover. I tried lock tyte and its not working too well.
Should i pick up one of those epoxy mixers? jb weld?
thanks
Old Aug 22, 2013 | 06:40 AM
wazzelby's Avatar
Are you talking about what to put on the threads to keep it from vibrating loose? I've never had a problem with it not staying tight. But, red locktite will hold that sucker in there. The blue isn't nearly as aggressive.
Old Aug 22, 2013 | 06:41 AM
thanks for the input.
im talking about the PCV into the valve cover. there are no threads on this.
Old Aug 22, 2013 | 08:42 AM
boostedwrx's Avatar
There's a fitting/collar that goes into the rocker cover first, then the PCV valve presses into that to stay in place.
Old Aug 22, 2013 | 08:49 AM
jerdeitzel's Avatar
I have tried numerous things to get it to stay in over the past 5 years. Nothing has worked. I bought a press in AN fitting and cannot keep that in without tying it down. I usually just vent to atmosphere after the first lap. . I dont even get all that much oil blowing out.
Old Aug 22, 2013 | 08:57 AM
jerdeitzel's Avatar
Maybe if you scuff up the valve cover the JB weld might stick better. The best i had at one time was by just piling JB on it and actually welding it onto the wire bracket near there. That held the longest. But, they all eventually blew out.
Old Aug 22, 2013 | 10:25 AM
hmmm i guess im not the only one having this issue then
BonsaiScott
Dec 19, 2016 04:26 PM
Mr2fine
Jan 9, 2013 04:50 AM
LakerRaider
Mar 27, 2011 06:40 PM
BluEVOIX
Apr 3, 2007 11:52 PM
wannaevo
Aug 18, 2006 02:19 PM
