Spark plug problem
Old Aug 18, 2013 | 04:14 PM
Viegasjuice's Avatar
Spark plug problem
Just swapped plugs to the same I've been using(ngk bpr7es) and now car will NOT idle and dies coming to a stop. What could be the issue? I gapped em at .025 and disconnected battery before starting. Also previous plugs had a bit of oil at the bottom and noticed the car before and now smells a bit like oil while driving
Old Aug 18, 2013 | 06:12 PM
gsrboi80's Avatar
You disconnected the battery, has to relearn idle.
Pretty common.
Old Aug 18, 2013 | 08:32 PM
Pretty common.
Really? Ive disconnected battery before and this has never happened. Is the bit of oil at bottom of spark plug normal? I also noticed, when i put in the new plugs, i tighten until it feels snug then it wont tighten anymore. Before if i tightened till snug i could still keep tighin easily..any ideas on that and the oil smell?
Old Aug 19, 2013 | 07:21 AM
egis's Avatar
I got smell of burning oil.when I start the car cool or hot I see blueish smoke for a sec.i take it as my rings are shot.
Old Aug 19, 2013 | 07:47 AM
crazybaldhead's Avatar
As the others said, car relearning idle. Will take a couple drives and then it will be fine. Take your time in the meanwhile.
Old Aug 19, 2013 | 06:57 PM
Car drives good once moving so ill see if it just needs time. I have no smoke out of tailpipe so the smell is odd. I have no idea why it smells like oil, i also have no visual leaks and im not losing oil
Old Aug 19, 2013 | 07:10 PM
Kada__85's Avatar
so should the battery be disconnected when changing the spark plugs?
Old Aug 19, 2013 | 07:34 PM
Im never doing it again, people have said to doit and ive done it before but this has never happened
Old Aug 21, 2013 | 10:52 PM
Thore's Avatar
The valvecover gasket around the spark plug holes could be leaking. Get oil in the combustion chamber and/or on the spark plugs, you can bet your car will run like sh*t
Old Aug 22, 2013 | 12:47 AM
That shouldn't be it. Moore automotive replaced my valve cover less than 1000 miles ago. What would be the symptoms?
Old Aug 22, 2013 | 07:12 AM
Rawger's Avatar
Are you checking your oil level and are you burning a lot of oil ? If you are it can be a couple of things but the biggest one is you might need a new piston ring. Yes that's gonna be money to fix, it also can be the valve cover gasket or PVC valve so start there and if still has blue smoke coming from the exhaust then You need new piston rings.
Old Aug 22, 2013 | 12:07 PM
Only thing i can think of is stuck pcv valve. No blue smoke, no smoke at all actually. Oil level is full its not losing oil.
SeahawksOilers
Apr 26, 2014 12:40 PM
Mark Hubley
Lancer How Tos / Installations
16
Feb 24, 2014 06:22 PM
oscs
Lancer Engine Tech
Oct 28, 2012 12:53 PM
campbmic
Mar 27, 2011 10:23 PM
iwantevonow
Jan 10, 2011 10:43 AM
