lack of power and backfire
Old Aug 31, 2013 | 08:54 PM
Bladey's Avatar
Hey all, I recently installed a new intake (used to have his one) and a 3" front pipe and resonated decat, after doing this I noticed the boost has increased a few psi and also at WOT at about 4.5k rpm the car starts backfiring , loses power/seems hesitant, after that it goes back to pulling hard till redline any ideas what could be causing this? I'm getting it retuned soon just waiting to buy a new turbo and injectors
Old Aug 31, 2013 | 10:11 PM
AndyCT9W's Avatar
How much boost are you hitting? What octane fuel are you using?
I'm thinking of two possibilities.
1. Too much boost and you're hitting boost cut.
2. You are running lean, knocking and pulling timing.
Either way you are in need of a tune, I'd avoid WOT until you are tuned.
Old Sep 1, 2013 | 04:50 AM
impact blue's Avatar
check for boostleaks then check your sparkplug gap. If your car is rich when you mash it like 10.0 when you hit boost and you feel looks you hit a wall of some sort sir you have a boostleak and the computer is trying to safeguard your motor.
Old Sep 1, 2013 | 12:21 PM
Bladey's Avatar
I think it's tuned for 21psi but I think I'm hitting slightly more, I use bp 98
Old Sep 2, 2013 | 09:56 PM
puk's Avatar
puk
My car does the same thing. I m running 28psi On e85
Old Sep 3, 2013 | 02:50 AM
AndyCT9W's Avatar
Fuel is ok. If you we're already hitting 21 psi before you are probably exceeding your boost limit. My IX cuts at 23.
Old Sep 4, 2013 | 10:18 PM
Socal's Avatar
What are your plugs gapped at? You probably just need to re gap them.
10isace
Sep 20, 2010 09:48 AM
racer135
Nov 5, 2009 07:18 AM
rawburt
10
Aug 2, 2009 06:00 PM
dasmyevo88
Jul 27, 2009 01:31 PM
jlam
Mar 4, 2008 10:27 PM
