Car backfires and sputters when the turbo kicks in
my 03 EVO is okay until the turbo kicks in. once it kicks in, the car backfires and sputters feeling like the cat back just wants to fall off.
it started after i changed the plugs so i changed those with some stock iridiums. it helped a little.
any help would be greatly appreciated.
You know I had a similar problem after I switched out my UICP, Turned out there was a pinch in the silicone coupling between the sections of the UICP. Went way rich and started kicking and bucking like a pissed off gelding with 50 mares around.
I also agree with checking the gap on the plugs, you can gap iridiums its just that you have to be extrememly careful not to damage it.
Josh
I also agree with checking the gap on the plugs, you can gap iridiums its just that you have to be extrememly careful not to damage it. Josh
THANK YOU all very much!
I took Alan678's advice and told my buddy to gap the plugs at .25 and that did the trick.
Mitsubishi had told me to gap their stock Iridiums at .45. Those SOBS!
Again thank you all, and a big thanks to Alan678. Y'all are the best!
IslandEvoIX
19
Apr 28, 2007 01:44 AM
2003, 2007, backfire, backfires, boost, car, controller, evo, greddy, kicks, mazdaspeed, mazdaspeed6, sputters, turbo, turbocharged, viii
