How to improve throttle response
Old Sep 9, 2013 | 05:09 PM
eddy5201314's Avatar
Hi, I've got a evo 5 with basic mods like exhaust and intake, aftermarket td05 16g, after I change my engine oil, I found that the throttle response sometimes is very slow, but sometimes it response fast. Is this because of the engine oil or something else? What can I do to improve the response?
Old Sep 9, 2013 | 05:14 PM
h22gordo's Avatar
Ported throttle body should help out with the response.
Old Sep 9, 2013 | 05:24 PM
Viegasjuice's Avatar
Tune
Old Sep 9, 2013 | 06:03 PM
cfdfireman1's Avatar
log it, see what's going on. could be knock or a loose wastegate. doubt very much it has anything to do with your oil.
Old Sep 9, 2013 | 07:14 PM
I'm planning to go reflash my standard ecu, will this help?
Old Sep 9, 2013 | 07:16 PM
PureDrivePerformance's Avatar
There may be something mechanical going on.
Did you adjust your throttle cable or mess with anything else? I know when I do my oil change I usually do a boost leak test, check all the clamps, hoses, etc. Maybe you bumped something loose. I don't think changing the oil will change your throttle response unless you put wheel bearing grease in the engine.
It could be in the tune, but if it was great before the oil change and now it's different, then it must be something mechanical. Did you disconnect your battery by chance when changing the oil?
Old Sep 10, 2013 | 04:21 AM
No... Does lager throttle body help? Is it has to change with injectors as well? Sometimes in a cold night, it response better.
Old Sep 10, 2013 | 04:43 AM
chu's Avatar
chu
Cooler/denser air at night time with make any car, especially turbo'd ones, run better.
Old Sep 10, 2013 | 05:40 AM
joseph143's Avatar
You dont need injectors with a throttle body unless evo 5's have tiny stock ones... The oem 550s we got are fine... Sorry a lil foggy on what you get. But yes the ported or new larger throttle body will help quiet a bit... Also a "induction cleaning" might help remove any build up that could be causing a restriction in your manifold... Vacuum leaks from old cracked rubber lines or a boost leak could as well... Have a shop smoke it and clean the intake
Old Sep 10, 2013 | 05:51 AM
meckert's Avatar
This is a distinct indication that its in the tune.. cooler denser air makes your car run a little leaner-- hotter thinner air, runs a bit richer-- try the tune FIRST before jumping to other conclusions.
Old Sep 10, 2013 | 06:01 AM
Sil'vr-Boi6's Avatar
which oil were you using before you started experiencing poor throttle response? 5W? 10?
Old Sep 10, 2013 | 10:21 AM
yellow303EVO's Avatar
take off your right shoe!
Old Sep 10, 2013 | 12:01 PM
crazybaldhead's Avatar
1) Place foot over right pedal
2) Mash vigorously
Old Sep 10, 2013 | 01:41 PM
Jimmy Javelin's Avatar
If lag is the issue during any temperature try adjusting the throttle cable like previously mentioned.
If it feels more responsive at night its the cooler/more dense air.
I've had the same issue; I got my tune in the winter and with it being summertime, I just need a tune.
If you try porting the throttle body without a tune you're gonna run into some A/F issues.
Happened to a buddy of mine, he had rough idle and a crappy ride.
Let us know if any of that helps resolve the issue.
Old Sep 10, 2013 | 06:08 PM
Thanks mate, I'll go for a tune.. and I have other question to ask, do you know what size is the evo 5 engine oil drain screw size and sump plug washer size? I'm planning to change oil this weekend.
CeliOnce
Feb 15, 2017 04:56 PM
alleggerita
11
Nov 8, 2014 11:43 PM
JDM.Spec
Feb 10, 2014 12:12 PM
jameswwt
Oct 19, 2012 11:21 PM
germanracing
Mitsubishi TC-SST Discussion
18
Jul 26, 2011 11:31 AM
