cf trunk fit
Old Sep 20, 2013 | 06:59 PM
evoiao's Avatar
cf trunk fit
hi everyone
Ive installed a cf vis duckbill trunk.....
fit fine...but.....theres always a but......
with both tension bars the trunk is like a catapult
no tension bars the trunk is too heavy and does not open.
one tension bar...one side of the trunk sit higher the the other side looks stupid....
any suggestion the correct the problem?
Thanks for anyone help.
Old Sep 20, 2013 | 10:01 PM
shimla's Avatar
I did one tension bar but it looks even. Hmmm? You might want to try the other tension bar, if still uneven, then order RS tension bars.
Old Sep 20, 2013 | 10:18 PM
evoiao's Avatar
r there any gas strut dampeners that fit the trunk of a 9?
Old Sep 20, 2013 | 11:16 PM
brent82187's Avatar
off topic, but any pics of it installed?
Old Sep 20, 2013 | 11:46 PM
Ian0611's Avatar
http://www.redlinetuning.com/QL-MITS...RUNK-0207.html
You're Welcome!!!
Old Sep 20, 2013 | 11:51 PM
Ian0611's Avatar
I've been dealing with this issue for about 4 months now. I ended up removing both torsion bars. I need to just break down and buy the Redline kit cuz right now I try to avoid opening my trunk as much as possible
Old Sep 21, 2013 | 10:33 AM
evoiao's Avatar
I looked up the redline kit it requires you to rivit it into the cf hood?
& they only make them for the hood not the trunk.
So far on the site most remove both bars and use tge carpet to keep the release up inorder to open the trunk.
I wanted to go upscale.
That soulution is not what I wanted to do.
What about taking evo x trunk brackets and using them?
Old Sep 21, 2013 | 01:16 PM
Ian0611's Avatar
The link I posted is for the trunk not the hood. Take a closer look
Old Sep 21, 2013 | 08:13 PM
evoiao's Avatar
Ok that looks nice I ordered the elite kit extra $50.00!
Thanks I'd never had seen
Both bar will come out and the kit is made with the intent to install with a cf trunk.....
Old Sep 21, 2013 | 09:54 PM
Ian0611's Avatar
Cool man! Make sure you post up your experience with it. I've only seen one other thread where a guy used it and he had nothing but good things to say about it. I'm hoping to pick up a kit soon my self.
Old Sep 22, 2013 | 01:55 AM
dutch sauce's Avatar
looks like a great idea
Old Sep 22, 2013 | 08:23 AM
evoiao's Avatar
If doesnt work then buy it fr om me!!!!
Old Sep 23, 2013 | 09:31 AM
DSMolition's Avatar
I just open mine with the key and hold it a bit so it does not slam open.. not sure why its a big deal.
Old Sep 24, 2013 | 10:02 AM
evoiao's Avatar
Originally Posted by DSMolition
I just open mine with the key and hold it a bit so it doses not slam open.. not sure why its a big deal.
Because I currently have not installed a lock to keep a flush look.
I'm sure the problem will be solved with the redline kit.
Old Sep 24, 2013 | 03:37 PM
Ian0611's Avatar
I also do not have a key hole. Furthermore, my trunk wouldn't sit right with the torsion bars installed. One side sat higher than the other.
