Evo VIII electrical issue??
Old Sep 24, 2013 | 05:31 PM
3V08GSR's Avatar
Ive got an 03 evo 8 gsr with a wiring problem. When the ignition is on everything works correctly. But when I turn the key off it cuts the power to everything. No power locks, no alarm, no headlights. Litterally everything stops working any ideas?
Old Sep 24, 2013 | 09:13 PM
adriano_917's Avatar
Thats weird! Check grounds and fuses, if you turn to ACC do you have power ?
Old Sep 24, 2013 | 11:15 PM
nelale2's Avatar
Based on the information you provided, I put together the wiring diagram for our car. Since the ignition is in the "OFF" position there aren’t relays or avenues that power can alternately route through. As you can see on the attachment, I colored red the wires that power will travel through to its respective systems. I highlighted yellow the things you mentioned in your post. I circled green the common area that all the items share. I would start there and work from there.
Old Sep 27, 2013 | 09:24 AM
impact blue's Avatar
Definitely check your grounds and fuses make sure the terminals have good contact with the battery and chassis with no corrosion.
Old Sep 29, 2013 | 09:32 AM
allevolution's Avatar
I'd say bad ground (since @ key on there is more amperage since more is powered on)
Or bad pin connections internally inside the ignition cylinder maybe?
Moore Auto
Evo X Dyno Results
Sep 11, 2020 09:00 PM
uneekvisions
14
Apr 8, 2018 08:57 PM
W0LF
16
Jul 9, 2017 05:53 AM
1STI2EVOX
Feb 18, 2017 01:27 PM
Death-Row
Australian Forum
Mar 11, 2010 07:14 PM
