Cost of making Power.
Old Sep 29, 2013 | 04:03 PM
chinolatino23's Avatar
Originally Posted by ReaperX
When making more power you also need to set aside more money for maintenance. Remember the law of car modding....
Fast & Reliable = Not Cheap
Cheap & Fast = Not Reliable
Cheap & Reliable = Not Fast
Pick your poison wisely.
Just what i was thinking.
Old Sep 29, 2013 | 04:55 PM
droppinbottom's Avatar
Originally Posted by batty200
10k can make almost any power level if you are frugal. You will spend a lot more if you build incrementally. Buying multiples of the same parts will kill a budget. Now a built trans can wreck any budget. But most street cars can use a stock transmission unless you are launching all the time and shifting at 10k. Keep in mind the initial build is not all you will spend. Breaking parts is a reality.
never in a million years will 10k get you into the 8xx range and allow the car to be somewhat reliable. (i still lol to myself when I say 8xx and reliable)
Old Sep 29, 2013 | 05:16 PM
gpfury86's Avatar
This would be more of an attainable number if the dog gear sets weren't 7-8k depending on exchange rate.
Old Sep 29, 2013 | 05:35 PM
joseph143's Avatar
a well built 5spd speed can easily hold 800... no need for dog boxes... also reliability goes out the window the further you deviate from stock... my car was bought new and stayed stock for 3 years... since then it has spent more time down then up. i get about a month before adjustments or repairs need to be made... my tcase, trans and diff are solid... mostly bolts vibrating loose from solid mounts and no balance shafts or valve train adjustments or the worst is turbo blow by issues... it doesn't help that its constantly being modified either... on this build i'm hoping to make 720+ on my ef4 but its not looking good... its cost me upward of 15k this time and this is build 3. 400 cost me 8-9k, 600 costs me 20k up front and 3-4k more following, and i'm building on each one. rather then removing and buying more parts... i have had 2 exhaust mani's 2 sets of cams, and upgraded from stock to green to ef4... other then that i haven't double spent on any parts...
this build was completely by me... as well as the first... the second was done at MAP and then a lil more by me... also i include everything done as part of the build... not just power adders... rims, hood, brakes and such are included...
Old Sep 29, 2013 | 05:46 PM
Viegasjuice's Avatar
20k for 600hp? Wat exactly was done
Old Sep 29, 2013 | 06:03 PM
Terror Rising's Avatar
Again, you're not adding up all the little things. I'm at $6k for 300 whp. But that includes tuning items, intake, exhaust, IC, fuel, wheels/tires, suspension, brakes, etc. Going fast takes a lot more than a turbo kit.
Old Sep 29, 2013 | 07:32 PM
I was actually asking for educational purposes
Old Sep 29, 2013 | 08:49 PM
Flsc300's Avatar
800+ is 30k if done right with supporting mods. Trust me when I tell you those little things add up quick. And that will get you a motor rated at 1000+. I never understood why ppl will have a motor built to withstand up to 800hp and push it to 800 and expect it to be fine. Its pushing it to the limit and only a matter of time before something fails.
Old Sep 30, 2013 | 07:10 AM
joseph143's Avatar
On the 600 build, ef4, rev 3 intake, stage 3 head, 5spd trans swap, 2.3 stg1, injectors, fuel pumps, tubular exhaust mani, complete valve train, new downpipe etc... My build sheet was 6 pages long
Old Sep 30, 2013 | 07:17 AM
Rik84's Avatar
I'm in an X not an 8 or 9 but the basics still stay the same. Also an MR instead of a GSR but what the hell...
I'm currently undergoing a pretty massive build for an MR. Just about everything has been built on the car, it is going to be one hell of a street car when finished. Looking at around 550 - 600whp on 91 as that's all I can get access to here.
I added up the entire build cost last night for the first time and I just about cried - I'm at $39,600. This includes all of my power mods, labor, vinyl wrap, suspension, wheels, transmission, CF aero bits, gauges etc.
Aside from pro time attack cars I'm probably getting close to one of the most expensive Evo X street car builds taking place. It hurts, but it should be pretty much bomb proof at 600whp and fun to drive every day.
I could have ~$17,000 and just built the motor and put a huge turbo on it with an SSP clutch kit but the chances of that lasting more than a season without something going boom is pretty slim. I've gone way over the top with custom stuff on the build, but it's awesome.
I've got a build thread on the other forum as this forum kind of pooped on my thread here for it not being on topic for a few posts. Dropped it after that.
Old Sep 30, 2013 | 07:40 AM
DSMdynamic's Avatar
The cost of making power is just too damn high
Old Sep 30, 2013 | 07:45 AM
Rik84's Avatar
Yah, it sucks. So does the 4 months my car has been gone. I've dumped that money into it without even seeing the damn thing in ages!
Old Sep 30, 2013 | 07:52 AM
chu's Avatar
chu
Suspension and tires isn't cheap either to be honest. Guys who time attack without a tire sponsorship are easily spending thousands each weekend.
Old Sep 30, 2013 | 08:05 AM
InoNothingMR's Avatar
This. Supporting mods supporting mods supporting mods.
If you are going to do it, do it right. Although itll hurt your bank account a ton itll pay off in the long run IMO
Old Sep 30, 2013 | 08:30 AM
TreatsIX's Avatar
Injectors $500
Fuel pump $200
Turbo $2200
Clutch $1000
TBE - $800
Intake - $300
Tune - 500$
FMIC + piping $1000
Cams - $500
550 WHP @ ~$6,000
