Install Cams with no tune ?
Old Sep 29, 2013 | 10:14 AM
JaYr_EvO9's Avatar
hello i have a evo 9 with the mods that are in my sig. I had a question i have S2 cams with new springs and retainers with ARP head studs could i install them and babe the car home untill i can get a tune it not my daily and probly wont drive until ready for tune? So the question is can i do the install and drive it ?
Old Sep 29, 2013 | 10:22 AM
misterevo8's Avatar
i would not, it will shift your maps greatly.
Old Sep 29, 2013 | 10:35 AM
rjfg's Avatar
^this
Old Sep 29, 2013 | 10:40 AM
ReaperX's Avatar
If you stay in vacuum you will be fine to drive it very sparingly. It will run very rich with the added volume of air it will be pulling in. So if you do, stay out of boost.
Old Sep 29, 2013 | 10:46 AM
adriano_917's Avatar
Just drive it like a grandma youll be fine.
Old Sep 29, 2013 | 10:54 AM
JaYr_EvO9's Avatar
Thanks guys for the quick response!!!! Some people have said with the mivec i should be fine but gramma it and dont be dum i should be ok
Old Sep 29, 2013 | 02:08 PM
hiboost2.0's Avatar
Do you have ecuflash? You're going to have to add timing at idle and maybe raise it a bit. Also you will need to tweak the MIVEC cam advanced map a little too to reduce the valve overlap...
I mean you don't HAVE to, but it will run a lot better if you do what I mentioned above.
Old Sep 29, 2013 | 02:46 PM
Raptord's Avatar
You'll be just fine. The idle might be a bit rough until it gets tuned, but nothing "hazardous" to the health of the vehicle.
Old Sep 29, 2013 | 02:53 PM
egis's Avatar
I drove it for 3 Weeks before tune.didnt beat on her of course.
Old Sep 29, 2013 | 04:06 PM
chinolatino23's Avatar
Got 272 cams, springs retainers, fuel injectors, arp headstuds, and a few other things. drove it under 2,000 rpms to the tune place and made it fine
Old Sep 29, 2013 | 09:10 PM
JaYr_EvO9's Avatar
no I dont have ecu flash
Old Sep 29, 2013 | 09:11 PM
JaYr_EvO9's Avatar
thanks again for the respons !!!!!
Old Sep 29, 2013 | 10:27 PM
PureDrivePerformance's Avatar
OP, you'll be fine. For peace of mind, I'd have at least a WB gauge to monitor AFR. You really should have a Tactrix cable and EvoScan to log.
I'm assuming your previous tune with Jamie has the knock light set up. With that I'd just stay out of boost.
Old Sep 30, 2013 | 12:03 PM
InoNothingMR's Avatar
I drove my car 400+ miles after cam install. Just babied it and watched my A/F gauge. You will be fine! Just dont wait too long.
Old Sep 30, 2013 | 03:12 PM
JaYr_EvO9's Avatar
ok thanks for response what do i kinda look for when watching my A/F gauge
