03 evo 8 exhaust leak?
Old Sep 29, 2013 | 10:29 PM
Micah123's Avatar
Ok so I recently installed exhaust on my car and I'm pretty sure I have a leak (pre turbo) but I can't tell if it is the problem or not, I am spoiling to about 15psi and then my car kind of cuts power and starts popping like it's missing or backfiring hard, no check engine light at all, it still spooks after that up to 24 psi I believe was what I've seen it get up to, but idling and just normal driving it's fine, it only does this when I floor it.
Any help or ideas would be great!
Old Sep 30, 2013 | 07:36 AM
DSMdynamic's Avatar
Yup, sounds like you might have a boost leak. Start by checking all the intercooler pipes, hoses, clamps, etc.
Old Sep 30, 2013 | 08:13 AM
Micah123's Avatar
If I have a pre turbo leak in my exhaust would that cause a turbo leak?
Old Sep 30, 2013 | 11:06 AM
Terror Rising's Avatar
If you had an exhaust leak pre-turbo it would affect how much boost you see but not how you run. The MAF is still counting how much air you're actually putting into the engine so you would be fine. Did you change anything else when you added the exhaust? How are your plugs?
Old Sep 30, 2013 | 12:52 PM
Micah123's Avatar
I'll check the plugs and get back but all I did was a full exhaust, and found a leak on the stock bcs so I put my electronic grimspeed one I ordered on and fixed that but it's still doing the popping at around 16+ psi and kinda lags usually happens at around 4-5 grand rpms
Old Sep 30, 2013 | 01:29 PM
minimarine09's Avatar
What is your afr doing at that rpm?
Old Sep 30, 2013 | 01:51 PM
Datalog and see if you can find it. The exhaust should move you further out in load so perhaps you're rich as hell or knocking.
Old Sep 30, 2013 | 02:15 PM
DSMdynamic's Avatar
The exhaust is AFTER the turbo, so a leak in your exhaust will not affect the turbo in that way, or give you the problem that you're experiencing.
How are your plugs? Have you checked all intercooler pipes for a boost leak? Understand that they're under a lot of pressure under boost, so it is possible that a leak can cause the spuddering that you're describing. These can be sneaky so make sure you take your time looking for them.
On a side note, you haven't touched the actual sensor inside of your MAF, have you?
Old Sep 30, 2013 | 03:25 PM
Micah123's Avatar
It's the manifold going to my turbo from my header.. That is also called turbo manifold or called header, or exhaust manifold, and u checked plugs, bought some new ones and now it's raining so I will replace them as soon as I can
Old Sep 30, 2013 | 03:27 PM
Micah123's Avatar
And I haven't touch the maf it has a hks intake on it
Old Sep 30, 2013 | 06:00 PM
Micah123's Avatar
Awesome! Thanks for the help it was the spark plugs! Never would have thought it was so simple lol
Old Sep 30, 2013 | 06:35 PM
DSMdynamic's Avatar
Cool, glad you got it working!
Old Sep 30, 2013 | 07:49 PM
You can never overestimate a problem in a turbo car. Glad the plugs fixed it and happy boosting!
Old Sep 30, 2013 | 08:27 PM
JaYr_EvO9's Avatar
khaled_hourani
15
Apr 24, 2017 04:10 AM
BOOSTINAT30PSI
24
Feb 8, 2017 07:48 PM
Gh3ttoRoM3o
Oct 7, 2015 09:54 AM
SLO-EVO
45
Mar 27, 2014 11:09 AM
mrfred
11
Jan 4, 2010 08:13 AM
