Boost control problems, running out of ideas!
Old Nov 4, 2013 | 07:25 PM
adriano_917's Avatar
Okay gents i need opinions here, im currently getting tuned by Tom on E85 and my boost will spike to 29-30psi but will fall to 20psi or so and it will not hold 25-26psi like Toms says it should and currently making 350hp with the mods on my sig. Ive done a boost leak test twice and fixed every boost leak also preloaded the wastegate to the max and its still doing the same thing by the way I have a grimmspeed ebc. Could it be the 3 port acting up or the wastegate is shot ?
Old Nov 4, 2013 | 07:34 PM
Terror Rising's Avatar
Are you sure it's the 3-port or WG? What have you done with duty cycle and boost error correction to diagnose this? I don't mean to disrespect Tom, just asking.
Old Nov 4, 2013 | 07:48 PM
That i dont know Tom is the tuner, like I said ive boost leak tested and found 3 leaks, one at the j-pipe and 2 hoses from the manifold. Wastegate doesnt look stock kinda goldish(stock is silver I think)
Old Nov 5, 2013 | 11:52 AM
I should also say that when I do a boost leak test all the way to 15psi the pressure goes down really really slow, that should be normal right ? If the 3 port wasnt working I wouldnt be able to boost to 30psi and hold 20psi or im just running 20psi from the WG being preloaded to the max and the 3 port is not working properly ?
Old Nov 5, 2013 | 01:12 PM
egis's Avatar
I'm not an expert by any means but if you connected your 3 port correctly then it must be wg.goldish color is stock wg color.i.feel your spring is to soft and you need wg actuator with 25psi spring(red color).good luck.
Old Nov 5, 2013 | 01:17 PM
I thought it was silver...
Old Nov 5, 2013 | 01:55 PM
hiboost2.0's Avatar
The stock wg is a goldish tint.
And you're tuning with tom right now? hahaha I emailed him a few days ago and got no response I thought he was on vacation or something LOL
Old Nov 5, 2013 | 02:31 PM
PureDrivePerformance's Avatar
You can test the WG by putting @ 12 psi to the inlet of the WG. See if it holds for 10 seconds. If it does then it's not the WG.
Old Nov 5, 2013 | 03:05 PM
itsmrrizz2you's Avatar
What is tom saying about all this?? Are you sure you have the 3 port hooked up correctly? I'm leaning more towards a faulty wga
Old Nov 5, 2013 | 03:06 PM
Also are you using the grim speed with a hallman mbc? That's how tom tuned my Evo I use both
Old Nov 5, 2013 | 03:26 PM
yes 3 port is plugged in correctly and its just the 3 port.
I will try this tomorrow.
Old Nov 5, 2013 | 03:27 PM
He's been pretty responsive to me.
Old Nov 5, 2013 | 04:43 PM
egis's Avatar
Ok so can you double check how you connected your 3port before you buy new wg?J pipe line goes to port 3(middle) and wg line goes to port 2(facing driver) and port uno not connected right?.
Old Nov 5, 2013 | 07:10 PM
Exactly like that! I guess the stock WG doesnt want to hold 25-26 psi.
