Tactrix 1.3 cable repair?
Old Nov 5, 2013 | 03:15 PM
black_beauty's Avatar
Is it possible to repair my cable or does anyone on the forum do it? I am having problems with the smaller white connector. Thanks
Old Nov 5, 2013 | 04:30 PM
itsmrrizz2you's Avatar
mine came out of that connector also. I just jammed the wire back in there and crimped it with a small needle nose and it has been good ever since
Old Nov 5, 2013 | 04:45 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Pics?
Is it a simple soldering job or...?
Old Nov 5, 2013 | 11:08 PM
It still seems to be in there, more like the wire may be broken inside? Can I check the volts coming out of the connector and if so what should it be?
Old Nov 6, 2013 | 05:13 AM
gsrboi80's Avatar
Did the wire pull out of the white connector?
Is the pin still on the end of the wire or is the pin still inside the connector?
Either way it's an easy fix if you can source that pin. I've got thousands of different style pins at work. If needed repin wire and reinsert into connector to lock it in place.
Old Nov 6, 2013 | 09:34 AM
visually it looks fine, the wire is still in the white connector. And the male pin is still in the cars connector. But I can't flash in a new ROM
DontStopMe
Mar 18, 2017 12:36 PM
hktrigguy
Oct 31, 2016 12:42 AM
XSilverJ
Aug 10, 2016 03:56 PM
ralliart123
Sep 10, 2014 06:45 AM
the_mork
May 7, 2012 09:11 AM
