Coolant leak
Old Nov 15, 2013 | 09:39 PM
  #31
barneyb's Avatar
I had a radiator cap leaking onto the top of the radiator. I had never seen a radiator cap do that before and so I thought, well, HG. However, a new cap was all she needed.
Old Nov 15, 2013 | 11:29 PM
  #32
Viegasjuice's Avatar
Did the cap look wasted?
Old Nov 16, 2013 | 08:48 AM
  #33
barneyb's Avatar
It was nearly new.
Old Nov 16, 2013 | 08:54 AM
  #34
Crimson_Phoenix's Avatar
Plastic end cap? Are you referring to the rad cap? I hear he hissing sound when I got back from a drive he day it happened.
Nah, it isn't the cap. There's this hairline crack that's running from front to back of the piece that the radiator caps screws on to.
I ordered a new radiator, hoses, and thermostat (since I'm in there); so that should square me away and have it quit hissing/spewing coolant everywhere.
Old Nov 16, 2013 | 09:44 AM
  #35
boostin4kix's Avatar
If it was me, I would just go ahead and change the radiator cap as it has the potential to be a cheap fix. However, if that doesn't take care of it, maybe you can try a compression check or better yet, a leakdown test. The results of those tests should tell you if your headgasket is blown.
Old Nov 16, 2013 | 04:10 PM
  #36
I'll look a little closer thanks for the heads up.
I have to get to that, I haven't been home. I'm going to take it to moore and do a HG with ARP headstuds anyways, the car has 105k on it and I wanted a new radiator so it might be time
Old Apr 24, 2014 | 11:59 PM
  #37
VanduzerWilliam's Avatar
Thread Revival!
Hello all, im currently dealing with something somewhat like this.. I have had the front smaller turbo coolant line blow, the 3/8 inner diameter line.
I replaced, then 2 weeks later, i blew the same diamater line behind the motor, going from the thermostat housing to the throttle body..
can anyone help me out with this? Why is this happening? Im guessing old age of rubber hoses as i have a 04..
but has anyone determined this to be something else?
I have a new w/p and HG and timing belt done 5k ago.
just replaced thermostat with new OEM from mitsu!
Old Apr 25, 2014 | 08:24 AM
  #38
Originally Posted by VanduzerWilliam
Thread Revival!
There could always be some underlying problems, but I wouldn't worry about it too much. I also blew the water line to my turbo, and i noticed that the hose was just in bad shape. Probably wouldn't be a bad idea to replace some of those hoses when you get the chance, just to be safe .
Old Apr 26, 2014 | 10:29 AM
  #39
slowsrt4:('s Avatar
easy fix, might be your thermostat is broken and is getting stuck open or closed.
Old Apr 26, 2014 | 07:18 PM
  #40
I ordered all the hoses last night that are OEM replacements from mitsubishi parts.net for the 4 coolant lines
Old Apr 26, 2014 | 07:20 PM
  #41
After the first blow out, (front line on top of turbo) i replaced thermostat. 2 weeks later i blew the back line (by throttle body to back of thermostat
EvoTeyn
Aug 27, 2011 09:23 PM
3BEEPS
Aug 24, 2011 07:00 PM
Parikh1234
Aug 19, 2010 11:53 AM
Johnboy1065
12
Jan 28, 2008 01:38 PM
use2vtec
16
Jan 19, 2008 11:45 PM
