help! launch control
Old Nov 24, 2013 | 03:31 PM
06ebevo's Avatar
Originally Posted by Boss777
It was tuned just not sure if ecu has to flashed or fuel pump is not good
so talk to your tuner.
Old Nov 25, 2013 | 09:57 AM
feautoevo's Avatar
Did I just read that you have a remote starter that tricks your car into thinking that the clutch is pushed in? or that the switch is bypassed, That is why your hitting stationary rev limit, your ecu will engage launch control when the clutch is pushed in, essentially it thinks it's pushed in all the time.. I'd get that little issue fixed.
Old Nov 26, 2013 | 07:50 AM
Boss777's Avatar
well i did knot know hot to explain yes i have bypassed switch thats what i wanted to tell for some reason when i start my car sometimes launch control is on and i start my car all the time with no clutch, but i figured out that i got different program i think i need to re-flash my ecu
Old Nov 26, 2013 | 03:41 PM
flippymcbean's Avatar
When you say bypassed do you mean unplugged? Because I have a remote start on my car and all I did was on plug the switch. And for my launch control to work I have to be in neutral or clutch in. It's weird how it works, but the previous owner set it up like that. I simply unplugged the clutch switch.
Old Nov 27, 2013 | 07:03 AM
obguilliams's Avatar
Lol don't get tune until you replace those spark plugs. I had the same problem, boost would hit and limp mode would set in around 4k. You most likely have some fowler plugs. I switched mine and solved the problem.
Old Nov 27, 2013 | 09:28 AM
Boss777's Avatar
Yeah good idea that what I was about to do wating for plugs from mail
Old Nov 28, 2013 | 08:26 AM
Boss777's Avatar
New plugs no change
Old Nov 29, 2013 | 08:08 AM
feautoevo's Avatar
Did you miss the part where I said if your ecu thinks the clutch is pushed in, it will activate the launch control... if you have your switch bypassed to have the alarm work I would hook that back up and see if it fixes your problem then figure out a solution for the starter.
Old Nov 29, 2013 | 03:51 PM
MYEVOVIII's Avatar
Question for you, is it hitting boost cut or revving like launch control does in first gear. It maybe you need to turn your boost down what PSi are you running up to and what octane gas are you using?
Old Nov 30, 2013 | 08:38 AM
Boss777's Avatar
It does on all gears its missfire or fuel cut or maybe my esc got mest up so far will see what they say in the shop I think after I reset check engine light it might mest up some file and it reads it wrong way
Old Nov 30, 2013 | 08:40 AM
Boss777's Avatar
No because it worked fine before
Old Nov 30, 2013 | 12:24 PM
MYEVOVIII's Avatar
The launch control will not work if your driving even if you push in the clutch and hold it in and rev to your set rpm. I again would like to know what is your set psi, sounds to me like your running lean and your Ecu is pulling to protect your engine. If your boost control is to high for your octane that's most likely what your experiencing. Turn your boost down to 19 and see if your still getting the same problem
Old Nov 30, 2013 | 03:14 PM
Boss777's Avatar
Boost is 28 psi on supreme like I said all was good the launch only glitch after check engine light was reset not it works bit stile it misfires or fuel cuts at hard gas it wont do if I press slowly also it only does in gears not in nutral
Old Nov 30, 2013 | 06:17 PM
MYEVOVIII's Avatar
That's your problem then your hitting fuel cut 28 psi is way too high for 93 octane.
Do you have a data logger? I would not go up to 28 unless you have race gas or meth/ water inj
Your getting knock which is cutting fuel and timing to keep you from blowing your motor. If you can get on a dyno or data log you will see it. Turn your boost down for pump I would go part 23 and that's if your have had it tuned for that. Best of luck turn the boost down and let us know I bet you will no longer experience the problem
Old Dec 1, 2013 | 09:16 AM
Boss777's Avatar
[AlYEVOVIII; 11038495]Tat's your problem then your hitting fuel cut 28 psi is way too high for 93 octane.
Your getting knock which is cutting fuel and timing to keep you from blowing your motor. If you can get on a dyno or data log you will see it. Turn your boost down for pump I would go part 23 and that's if your have had it tuned for that. Best of luck turn the boost down and let us know I bet you will no longer experience the problem[/QUOTE]
It was tuned like that at English racing about year ago what previous owner told me And all was good UntiLe check engine Light was reset
Enjoi926
May 31, 2017 06:47 PM
dillons13
Sep 2, 2015 06:25 AM
NoClanSWAT
Lancer Engine Tech
Oct 9, 2012 09:10 AM
Arkitek
18
Jun 27, 2010 06:53 AM
xxxevo8xxx
AEM EMS
13
May 31, 2008 03:03 AM
