AEM EMS Get tuning help for your AEM EMS system.
AEM misfire problem
Old May 18, 2008 | 06:46 AM
xxxevo8xxx's Avatar
AEM misfire problem
I just put installed the AEM EMS in my car. The car now misfires under boost and has a little misfire just cruising. Has anyone else had this problem with the AEM. I am using the stock coils. Do i need to upgrade the ignition????
Old May 18, 2008 | 11:32 AM
xxxevo8xxx's Avatar
anything????
Old May 18, 2008 | 11:41 AM
SparkTech's Avatar
sounds more like tuning...but depends on how much boost your running. The stock coils are not consistent some will make 400hp some 500hp...without severe misfires. Stay tuned as we are in the final stages of testing our non-cdi coil on plug. These feature 4 individual high powered coils.
Old May 18, 2008 | 02:17 PM
xxxevo8xxx's Avatar
I am running 25lbs with full race TS 35R kit.
Old May 18, 2008 | 02:20 PM
SparkTech's Avatar
what spark plug gap?
Old May 18, 2008 | 02:26 PM
xxxevo8xxx's Avatar
we went all the way down to .018. It got a tiny bit better. So i am thinking the stock coils junk.
Old May 18, 2008 | 02:36 PM
SparkTech's Avatar
yep...sounds like coils
Old May 23, 2008 | 03:10 PM
xxxevo8xxx's Avatar
bump
Old May 24, 2008 | 12:09 PM
GTVEVO's Avatar
22-25 lbs is all you will get with stock coils on any turbo 50trim or bigger. If you change the plugs they will only last for a few pulls then crap out again. The EVO coils don't perform well with the AEM box, exactly as too why I don't think we will ever find out becuase the AEM support group is CRAP. I ended up having to build my own ignition using a 1g could and ignitor and it works like a champ.
Old May 25, 2008 | 12:30 PM
DG Motors's Avatar
I am running 42lbs with stock coils and an hks dli2. So far 5 tanks of c-16 and a 100 pulls no problem.
Old May 25, 2008 | 12:50 PM
GTVEVO's Avatar
If you are using the AEM EMS consider yourself very lucky. Are you running the stock AEM settings or have you changed the dwell settings at all?
Old May 25, 2008 | 12:53 PM
evo_08's Avatar
go to nj there is a shop in linden by the name of iveytune,theyll hook you up.
Old May 25, 2008 | 06:52 PM
MZP@TeamD's Avatar
Former Vendor
AEM misfire problem
Can you post some datalogs ?
Old May 31, 2008 | 03:03 AM
xxxevo8xxx's Avatar
The cars doing back to DSG on the 10th for another tune. We will see what happens.
maknuge
Nov 18, 2015 12:04 PM
Boss777
Dec 1, 2013 09:16 AM
Secret Chimp
576
Mar 24, 2012 10:18 PM
mrboost05
14
Sep 26, 2011 12:05 AM
Arkitek
18
Jun 27, 2010 06:53 AM
