Proper wheel fitment Enkei Nt03
Ok so ive read the other threads on this situation, but I cant really find specifics on my tire selection. So I have a full set of Enkei Nt03 18x9.5+40 with .25mm spacers in the front. Currently im running a set of Bayspeed wide flare front fenders, but would like to go back to OEM fenders. My question is if im running a 255/35/18 tire can I stick these rims under my car without any rubbing issues if I decide to go back with OEM front fenders????Thanks in advance
If you use a 15mm spacer or so it will be perfect fit (Not sure if 15mm will clear Brembo or not through)
I would recommend 265/35/18 because the rolling diameter is like stock rather than slightly shorter like 255/35/18
Most likely you will need to roll your rear fender
This is exactly what i was looking for
Looks great, i have had my wide fenders on with this set up so i wasnt sure if OEM fenders were an option with this offset without alot of rolling of the front fenders.
eddy5201314
13
May 18, 2020 02:55 PM
illvolution
Sep 24, 2012 02:22 PM
Blue91lx
26
Jul 11, 2012 12:58 PM
eliminator 429
15
Mar 23, 2010 10:41 AM
