Evo VIII Sunroof Issue. Please help me fix this thing PLEASE
Old Dec 11, 2013 | 08:28 PM
AKW89's Avatar
Unhappy Evo VIII Sunroof Issue. Please help me fix this thing PLEASE
Okay,
So first and foremost my car is an Evo VIII with 28k miles and has a sunroof. The sunroof was working wonderfully, never made noise, never did anything stupid. One day I went out to the car and it just stopped working. It had set over night and it is closed.
I took the headliner down, looked at the teeth on the motor, looked at the winder for the window and it was all good. I took the motor out and all the screws were there. Took the motor and a 12v battery and put power to it, it spun both ways freely and fine.
I reinstalled the motor and it still does NOTHING. There is no power, no click, no wine, no NOTHING. I switched the relays around in the car hoping for one that may have been messed up, got nothing. I do not even hear this motor clicking TRYING to spin and it just being weak. Is there ANYTHING that someone knows that I don't? Because I really do like a sunroof and that's why I have one. Please help me fix this thing.
Old Dec 14, 2013 | 09:45 AM
CNC_OUTLAW's Avatar
That sucks man, I’m dreading the day that mine goes out. Wish I could help...
Good luck
Old Dec 14, 2013 | 10:00 AM
1UpMoto's Avatar
Check the switch
Old Dec 14, 2013 | 10:11 AM
Sheasta's Avatar
Are you getting 12v to the motor from the connector? If it was trying to spin but sounded weak it probably has high resistance. Like the power wires frayed etc.
Old Dec 14, 2013 | 10:20 AM
foxbear2277's Avatar
Check all power supplies and grounds. Get a wiring diagram if possible and disconnect the motor. Use a DVOM to measure at the motor with switch pressed and proceed to check the different areas of the circuit to ensure power supplies and grounds are o.k. Make sure all fuses are not blown. I would suggest to check power supply to the switch. If there but no voltage to the motor but voltage to the switch, I would deem that the switch has gone bad.
Another thing to check would be to remove the relay and check terminal 30 (constant power) as well as terminal 85 (relay ground).
Hope this helps and good luck
Old Mar 22, 2014 | 05:48 PM
AKW89's Avatar
I finally got less lazy and looked into this. The motor, wiring, and everything was fine. The issue was the control module board. So I found a wrecked lancer with a sunroof and bought the board only (much cheaper than the motor). Now the sunroof works like the champion it is. Hope this helps others.
Old Mar 23, 2014 | 09:15 AM
jrainwater's Avatar
Where's this control module board that you speak of located at inside the cabin? I'm more just curious because I have a sunroof (SSL) and this info might come in handy one day. Thanks.
Old Mar 25, 2014 | 05:20 PM
c_evo8's Avatar
Glad you fixed your problem
Cajun Power
189
May 19, 2020 09:27 PM
ATTAHO
Nov 5, 2018 06:51 AM
Soshina Yang
Lancer Troubleshooting
Nov 2, 2016 10:22 AM
Jimbolution
Sep 1, 2015 07:50 PM
ZFRED10
Jul 20, 2014 07:05 PM
