Hks F-con v pro vs link g4
Old Jan 9, 2014 | 01:14 PM
Evo5madness's Avatar
Just about to do ecu upgrade. Dealing with two options. Hks fcon v pro and link g4. Any info would help on the best out of the 2. Also please include addition stuff I will need to purchase for each. Map sensors, harness etc. 1998 evo 5. Cheers guys
Going to be plug and play so harness a must
Old Jan 9, 2014 | 10:42 PM
No help?? Come on guys help me out. This an important decision for me
Old Jan 10, 2014 | 01:18 AM
hycool's Avatar
My feedback on the Fcon
This is my setup:
HKS Vpro v3.24 with evo 9 harness
HKS MAP and IAT sensor with harness
HKS navigator - removed
Custom push switch as Scramble switch for 2 step
PLX AFR analog output wired to HKS fCon for Air/Fuel ratio feedback control
Future plan - install Valcon for Mivec tuning or sell the valcon and use ecuflash
1) i have a communication cable(cable provided in the EVC software) for reading and writing maps to my fcon. This is setup if i need remote tuning from fcon tuners
2) i have connected the PLX AFR to my fcon harness for AF feedback, this is one of my fav mod done so far
3) i don't use the 2 step but it was installed and setup by previous tuner
4) I removed the navigator(older version) since it has limited monitoring values and does not give you the capability to change map (only possible for non fcon vpro). the navigator pro does allows for custom value reading from fcon
5) Currently runnning D-Jetro(equivalent to SD) which eliminates the MAF
- Setup has been stable and hasn't given me any problems in my 4yrs of ownership. i have tuned it twice so far, 1st time when i first purchase my car(2009) and it came installed with fcon. 2nd time last year with the setup of the A/f feedback
- Able to setup up Air/Fuel ratio feedback and Fcon does the adjustments in all conditions (idle, cruise or WOT)
Dislike:
- Not able to tune Mivec. Options available is to either edit the Mivec map thru ecuflash or get my valcon(lying in my storeroom) installed by HKS
- Limited tuners in my region since it is not open source, thus using remote tuning by fcon tuners
- Not able to revert back to stock since i no longer have the MAF, which is not an issue since i have no plans to remove it.
Old Jan 10, 2014 | 04:29 AM
maikcat's Avatar
@hycool
instead of buying valcon you can buy fcon V4 (swap?) which handles mivec
Michael.
Old Jan 10, 2014 | 08:01 AM
hycool's Avatar
Originally Posted by maikcat
@hycool
Michael.
V4 is still too new and a totally new ball game. It does not have a harness for evo9 yet and i have not seen anyone using it. besides, i will lose the flexibility of flashing maps as i wish and most prob lose my AF feedback setup with PLX as well
lanevo7
Jan 23, 2016 04:56 AM
EvoDan2004
17
Jul 4, 2014 10:42 AM
illusin
AEM EMS
Mar 18, 2014 12:47 PM
memphis raynes
Nov 23, 2013 11:48 AM
BadAssEvo
Nov 2, 2013 05:40 PM
