TB leak, NOT shaft seals...
Old Jan 31, 2014 | 08:17 PM
black_beauty's Avatar
My TB is leaking on the back side UNDER the TPS. Idk what it is but I took the TB off the get a better look and heres what I found... Can anyone tell me how to fix it or why its leaking?
Old Jan 31, 2014 | 08:19 PM
This?
Attached Thumbnails TB leak, NOT shaft seals...-image-268659991.jpg   TB leak, NOT shaft seals...-image-701916477.jpg   TB leak, NOT shaft seals...-image-549733766.jpg   TB leak, NOT shaft seals...-image-2165957100.jpg
Old Jan 31, 2014 | 08:30 PM
Low Life's Avatar
Bliss screw O-ring. I have a few spares I can send you in case you can't track one down.
Old Jan 31, 2014 | 08:32 PM
Low Life's Avatar
Do you have the other half to the plastic piece in the last 2 pictures?
Old Jan 31, 2014 | 08:33 PM
lostsoulsevo's Avatar
That throttle body looks in bad shape
Old Jan 31, 2014 | 09:04 PM
There was only 1 half moon piece in it?
Old Jan 31, 2014 | 09:06 PM
rcheung's Avatar
Thats a throttle position sensor. The biss is on the other side.
Old Jan 31, 2014 | 09:09 PM
jrainwater's Avatar
That thing he is holding is not a biss screw. The thing in my pics is a biss screw. Second pic is on an envelope for size reference. The thing he is holding is located just below the tps inside of the throttle body and I've never heard of anyone taking that part of the throttle body off. I'm not even sure its supposed to come off. You probably need to buy a used throttle body off of here or eBay. I don't think that broken part is available by itself.
Attached Thumbnails TB leak, NOT shaft seals...-forumrunner_20140131_230356.jpg   TB leak, NOT shaft seals...-forumrunner_20140131_230425.jpg
Old Jan 31, 2014 | 10:11 PM
Def not a BISS screw
Old Jan 31, 2014 | 10:14 PM
I know that SOB was leakin a ton and wasn't 2 weeks ago
Old Jan 31, 2014 | 10:27 PM
jrainwater's Avatar
Are you positive it was leaking from that part that you removed and not from the tps side throttle body shaft seal? Maybe the air was shooting downwards toward that circular piece that you pulled out? The reason I ask is I thought that little circle piece with the screw in it was a way to bleed air out of the coolant passages at the factory when the vehicle is being assembled. I'm not sure if air passes through that point but I could be wrong. :-/
Old Jan 31, 2014 | 11:07 PM
I re did my TB shaft seals less than 1k ago
Old Feb 1, 2014 | 12:01 AM
PureDrivePerformance's Avatar
Mine leaked too. I just put a new o-ring and its fixed. The Evo ix don't use that piece. It's an empty space.
Old Feb 1, 2014 | 12:06 AM
jason42003's Avatar
That's an evo 8 tb and they have the flapper for the iac, I'm not 100% on the purpose but I was just looking at milspec's tb and I remember them saying that you must make sure that you have the right year tb sent to them because the evo 8 has that flapper and the evo 9 doesn't. You might try contacting them and see if they can get you a replacement or just throwing a used tb on there.
Old Feb 1, 2014 | 02:16 PM
I just read my previous post. I meant to say that it's an evo 8 TB, but the 9's revised it and don't use that.
It's heat activated bleeder flap. Pic and info via Aby at MIL.SPEC's post.
I have a Mil.Spec 65mm Evo IX in stock fresh from them. PM me if interested.
