DSport Mag has Evo cam test part 2 -- all 17 cams.
Old Feb 10, 2014 | 07:56 AM
  #31
doghouse's Avatar
Nice Tomei is SUPER
Old Feb 10, 2014 | 12:44 PM
  #32
Fast_Freddie's Avatar
Veteran: Navy
The Tomei 290s would be IMHO a crap cam on a street and occasional track car... it lost tons of power under the curve... however for a drag only car, these look like they performed. I would venture to say that these cams would more than likely be crap on an OEM non-ported head as well, as you would not be able to take advantage of the benefits if the longer duration.
Old Feb 10, 2014 | 01:57 PM
  #33
tommyf's Avatar
Nothing on the mods done to tested car(s)
Old Feb 10, 2014 | 04:08 PM
  #34
TheBoz's Avatar
Eletronics
- AEM Infinity 8
- AEM WB
- AEM Analog Fuel and Oil Pressure
- AEM Analog Oil Temp
- AEM 5bar Map Sensor
Intake
- Custom 4" intake
- AMS F1i unported
- Oem Throttle Body unported rebuilt by Mil.spec
- DIY LICP
- ETS 3.5" FMIC
- ETS Ti UICP
- Tial BOV
Fuel
- Skunk 2 Fuel Rail
- FIC 2150cc
- Squash Performance Double pumper(dual 450's)
- Aeromotive FPR
- -6 supply and return lines
Head
- Bowl Blend
- Clean up flashing
- AEM Adjustable Cam Gears
- GSC S2 Cams(all the other cams they tested)
- GSC Zero Tick Lifters
- Supertech Duals
- Supertech Valves
Block
- 4G63 2.0
- Carrillo Rods
- CP Pistons 10.5:1
- ARP 625 Plus Head studs
Turbo
- JMF stock location Vband Manifold
- FP 3586hta .63 Tial housing
- Custom Exhaust
Car was running from the pump E85. All pulls were done at 20 or 21psi(I don't remember exactly which one).
Old Feb 10, 2014 | 05:45 PM
  #35
Nohatn's Avatar
Tomei not joking around 270 did hella good against the 272 line up!
Old Feb 10, 2014 | 10:37 PM
  #36
lv05evo's Avatar
How did you get these specs?
Originally Posted by TheBoz
Eletronics
- AEM Infinity 8
- AEM WB
Intake
- Custom 4" intake
- AMS F1i unported
- DIY LICP
- ETS 3.5" FMIC
- ETS Ti UICP
- Tial BOV
Fuel
- Skunk 2 Fuel Rail
- FIC 2150cc
- Aeromotive FPR
Head
- Bowl Blend
- Clean up flashing
- Supertech Duals
- Supertech Valves
Block
- 4G63 2.0
- Carrillo Rods
- CP Pistons 10.5:1
Turbo
- Custom Exhaust
Old Feb 11, 2014 | 01:03 AM
  #37
okevolutionVIII's Avatar
Nice to see my Tomei 270s over powered the S2 and Kelford 272s but I bet the torque down low did the same to both.
Old Feb 11, 2014 | 03:06 AM
  #38
Jsiebert's Avatar
I bet the 290 tomei cams with a ported stock manifold would have been nasty.
Old Feb 11, 2014 | 03:11 AM
  #39
Fireescape's Avatar
As an GSC R2 user I'm biased but I'm pretty impressed with how the R2 went. The rpm range is huge, good max power at 8500 and max torque at only 6000, better than the S3's. I can also say, on my Mivec set up at least, they drive better than stock.
Old Feb 11, 2014 | 06:38 AM
  #40
Grimgrak's Avatar
How often are you in 0C weather?
Old Feb 11, 2014 | 08:22 AM
  #41
Aby@MIL.SPEC's Avatar
would love to see the s2 vs r2 comparison / overlay.
need to install my r2's!
Old Feb 11, 2014 | 09:36 AM
  #42
Veteran: Navy
You need to so I can see a "camparison" between the two... I have been contemplating making the switch but haven't seen anything near my setup so I am hesitant to take the plunge...
Old Feb 11, 2014 | 09:37 AM
  #43
TheBoz's Avatar
That is my car.
Old Feb 11, 2014 | 10:42 AM
  #44
J_Striker's Avatar
That is my car.
Sorry to hear about the engines that died, and the clutch that went while doing this cam test.
Old Feb 11, 2014 | 11:00 AM
  #45
Ev0ikon's Avatar
I wish they could do a 2.3/2.4 stroker test also. I bet the R2 would shine even more!
