DSport Mag has Evo cam test part 2 -- all 17 cams.
Old Feb 11, 2014 | 11:52 AM
  #46
Aby@MIL.SPEC's Avatar
Originally Posted by Ev0ikon
I wish they could do a 2.3/2.4 stroker test also. I bet the R2 would shine even more!
my compare will be s2 vs r2 on a 2.4 / hta grn / e85 @ 28psi
I may throw the cams in this weekend......maybe not....im lazy & my back is shot...
Old Feb 11, 2014 | 06:44 PM
  #47
Fireescape's Avatar
Originally Posted by Grimgrak
How often are you in 0C weather?
Do you mean below freezing. Never. I'm about 1 hour south of Sydney, coldest winter would be maybe 2 or 3 degrees celsius, we have had snow once in 10 years.
Old Feb 11, 2014 | 10:02 PM
  #48
evotuner04's Avatar
15 Year MemberLikedLoved
I'd like some of this!! I have Kelfords on my EF2.5 and 2.3 but hasnt had the ***** out tune done yet since I finished break in right before Decemeber
Old Feb 12, 2014 | 12:32 AM
  #49
lv05evo's Avatar
Originally Posted by TheBoz
That is my car.
Can I ask who did the clutch install? You can PM me if you want.
Old Feb 12, 2014 | 01:34 AM
  #50
patryko's Avatar
Can somone make scan and take grafs ??
Old Feb 12, 2014 | 03:42 AM
  #51
Fast_Freddie's Avatar
Veteran: Navy
Do it, I have a 2.4 with S2s and FP Red on stock head, so I wanna see how the R2s effect the power band on a 2.4 with stock frame turbo...
Old Feb 12, 2014 | 07:30 AM
  #52
went to barnes & noble last night, they only have the feb issue = 1st part of test.
I will scan & post graphs when i get the 2nd issue of the cam test.
where did people locate the 2nd issue? what store?
Old Feb 12, 2014 | 08:39 AM
  #53
TheBoz's Avatar
I did, and it was my dumb *** fault that the motor blew up.
When swapping the clutch I was lifting the motor from the oil pan. This dented it and removed all the clearance between the oil pan and the pickup. I would only see oil pressure drop off after 6500 rpm. I have done clutches more than 10 times when you add it with my Galant and the Evo, this time I was just in a hurry and cut some corners. It bit me in the ***.
So I did plan to do the clutch and rebuild the motor during the winter, so this just put all that into the works about 1 month early. So about 7500 bucks later they had the car running the way they needed it for the tests. I am sure that I am missing something, but 7500 sounds about close.
Things done to it during the test:
1. QM 8 Leg Twin Plate -- MAP was awesome, they next day air'ed this to me
2. Rebuilt Motor and head -- RRE helped out with a used crank
3. Rebuilt Throttle body -- Thanks Mil.Spec
4. FIC 2150cc injectors again -- I switch injectors like underware
5. Squash Double pumper with Dual 450's
6. Upgraded to -6 supply and return lines
The guys at DSport are really awesome, they did everything in there power to help out where possible.
Old Feb 12, 2014 | 08:11 PM
  #54
deylag's Avatar
Safeway
Old Feb 12, 2014 | 09:03 PM
  #55
TommiM's Avatar
I found mine across the street at Rite Aid.
Old Feb 12, 2014 | 09:33 PM
  #56
Grimgrak's Avatar
That explains your "like stock" start up/idle.
Old Feb 12, 2014 | 09:38 PM
  #57
e_kobz's Avatar
I got mine at a local grocery store
Old Feb 12, 2014 | 09:45 PM
  #58
B&N
Old Feb 13, 2014 | 01:00 PM
  #59
10isace's Avatar
Finally found part 2 at Wal-Mart of all places. I avoid Wal-Mart, so it was my last effort. They had a boat load of them.
Old Feb 13, 2014 | 03:57 PM
  #60
mitsubeastlee's Avatar
somebody be a gent and scan it all on to the forums so we have it forever!!!!!
