Annoying lack of idle
Old Feb 25, 2014 | 05:39 AM
UberDalum's Avatar
Originally Posted by ProPilot04
Ok... a couple things.
1. If you're running a different BOV, pipes, and turbo... it needs a tune. That said, it's strange that this wouldn't occur more often other than temp related...
I think I'd suggest a boost leak test just to get it out of the way... otherwise, do you have an AFR gauge? What are the readings on that? I'm wondering if there's an O2 issue (though you'd get a CEL typically... unless it's disabled, but maybe those codes...) when it's switching between closed loop, and open loop ops.
I'm looking to get into tuning the car. Was planning on the summer sinceI was going to do a few more mods (COP setup maiinly in the engine area) since the car isn't really breaking down, I'm OK enough with it till I can get into better weather before jumping into this.
I'm fairly new into having a turbo car and I've done off the shelf bolt-ons on previous cars but nothing really major. With that being said, I've been doing a LOT of reading and realized that I'm a smidge over my head and had no clue about things like leak testers and other things to keep track of the car. Being more nerd than mechanic, I hooked up on Torque after buying a bluetooth OBDII adapter. I am in the beginnings of compiling my data so I can get a better idea of what to say when all of you start asking questions
With that being said, here is my P-code data from this morning:
Fault log report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: MN132874AB
Current Fault Log
P0300: Random/Multiple Cylinder Misfire Detected
Pending Fault Log
ECU reports no pending faults
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
ECU reports no other fault codes logged
End of report.
I know it's not much so far but since accidentally clearing out my codes when I got the app, I had a feeling this one would come back.
turbotaloon95
E85 / Ethanol
14
May 7, 2019 03:52 PM
Arsenal4Life
Jan 8, 2014 09:58 AM
HornstarBU
Jun 7, 2011 06:00 PM
orion981
Jan 21, 2005 02:47 PM
93civEJ1
Jan 17, 2005 10:12 AM
