Evo 4-6 4g vs USDM Evo 8 4g63
Old Feb 22, 2014 | 10:50 AM
BrunoBoy650's Avatar
Hey guys, I am currently starting a project i tried starting two years ago when funds were low. I want to swap a 5g mirage to Evo 6. Again I live in California where the motor swap will need to be Bar'd. I know with 5G mirages, the Evo 4-6 engine harness will have to be used as its a plug and play with the dash and interior harness. I already know what needs to be swapped to make it AWD or FWD so its not that kind of question. The main question I have is if the Evo 5/6 4g63T share the same Sensors as the USDM Evo 8? Also when I Bar'd my civic for a B16a2 swap, they checked the block number, the head number and ecu. Does the Evo 5-8 all have the same number stamps that would look the same to the technician? I have found its way cheaper to buy a 5/6 motor and trans with X case for the mirage rather than piecing together an 8 motor and trans. If there is any differences, please list them here between the two. I don't mind getting the Emission stuff to make the 5/6 motor work as long as I know for sure that the numbers and such are all the same. Thanks
-Shane
Old Feb 22, 2014 | 09:01 PM
no one? can someone please snap a pic of both head and block markings of their Evo VI engines and same for the VIII Engine. Thanks
-Shane
Old Feb 23, 2014 | 12:37 AM
shak2300's Avatar
i cant really answer that question mate but hopefully this thread might help you out somewhat it give a lot of info, the the OP use the evo 5 engine with evo 8 ecu , but don't quote me on that it been awhile since i have read it
good luck
https://www.evolutionm.net/forums/ev...onversion.html
Old Feb 23, 2014 | 01:51 AM
thanks! I forgot all about 3Bars build. does anyone else know at the moment ? Ill PM him though.
-Shane
Old Feb 24, 2014 | 09:24 AM
bump.
Old Feb 24, 2014 | 09:36 AM
Paul Walkin's Avatar
Sensors are similiar and you can get them to work with a Tephra modded Evo 8 ecu. Same "number stamps"
Old Feb 24, 2014 | 11:09 PM
very good to know, thanks! as long as the head and block have the same numbers as a VIII, It should be all good. Thanks again
-Shane
Old Feb 26, 2014 | 10:47 AM
hey, bump, I had someone on the mirage forums post this to me, can someone confirm please?
Evolution VI:
Evolution VIII:
"The engine number can be seen on the front left of the engine (when standing at the front of the car) about half way down the block, stamped in to the block.
EVO I: MX, NX, PB
EVO II: OP, QV
EVO III: PP, SD
EVO III/IV: TB, TE, TF, TG, TH, TJ, TK, TL, TM, TN, TR, TS
EVO V: XG, XH, XJ, XK, XL, XM, XN, XO, XP, XQ, XR, XS, XU, YJ (V RS LHD)
EVO VI: AA, AB, AC, AL, AM, AN, AO, AP, AQ, YN, YR, YS, YT, YX, YY
EVO VI TME: BB, BC, BD, BG, BJ, BK, BL, BM, BX
EVO VII: CS, CT, CX, CY, DA, DB, DC, DG, DK, DN, DR, GB, GC, GL, GN, KA, KC, KD
EVO VIII 260: HY (USA), JX, KL, KO, KQ
EVO VIII: HM, HP, HQ, HR, HT, JC, JD, KM, KS
EVO VIII MR: JY, KA, KB, KC, KD, KH, KJ, KK
EVO IX: KQ, LA, LB, LD, LG, LH, LJ, LK, LQ, LS, MM, MN, NB (USA)
EVO X: 4B"
Old Feb 26, 2014 | 11:29 AM
cmspaz's Avatar
I've got a ton of Evo IV stuff sitting around including a shortblock, the harness is clipped and missing a few plugs but if you need me to look at anything specifically or are looking for something let me know.
Old Feb 27, 2014 | 12:10 PM
-Shane
It will not have the same numbers, it is not a VIII block. Each variation block has individual letters/numbers to identify it. What you will have is a serial number stamped into the block in the same location as your VIII. Whether or not that is acceptable in your state, I cannot answer.
Where is this head number you speak of?
Live4Redline
Mar 27, 2026 01:19 PM
Alchem1st
Mar 15, 2022 08:47 AM
Alchem1st
Mar 12, 2018 03:37 AM
BrunoBoy650
12
Mar 9, 2014 10:29 AM
Alchem1st
For Sale - Cars For Sale
Jan 2, 2013 01:57 PM
