evo ix engine code after cam install
Old Feb 23, 2014 | 06:59 PM
gg2006ssl's Avatar
I have a question I tried searching on the forum no real concrete answers threw a p0365 after intalling my cams double checked everything and everything is good timing is on point everything is good any suggestions to fix
Old Feb 24, 2014 | 08:13 AM
gg2006ssl's Avatar
has nobody had this problem?? they are gsc s1 cams thanks for any help
Old Feb 24, 2014 | 08:18 AM
SW20Mike's Avatar
Veteran: Air Force
CAS error code right? If your car is running right besides the CEL, then clear the code and see if it returns. Usually when folks screw up putting the CAS back in, it is installed 180 degrees out and the car won't start.
Old Feb 24, 2014 | 10:10 AM
gg2006ssl's Avatar
car is running fine just goes into limp mode when light comes off sounds like it wants to die but then idles right back up... also cleared the code 3 times comes right back on 5 min later again
Old Feb 24, 2014 | 12:54 PM
pr0phet's Avatar
I am having this same issue except when my builder monitors with evo scan all a/f ratios, timing etc look fine. So far we have replaced both sensors and still pops code. I have been scouring internet to no avail. I have GSC S2s tho.
Old Feb 24, 2014 | 01:16 PM
meckert's Avatar
Judging from the code its the CAS.. However, have you checked the connections and the wiring cause the code also says its not getting a reading at the ECM.. Could be the sensor itself, but since you had to pull the connection I would look at everything.
Old Feb 27, 2014 | 07:46 AM
gg2006ssl's Avatar
yes actually I checked everything unplugged the sensor then plugged it back in cleared the doe now it decided to work everyhting seems to be worrking fine now thanks for all the info though I appreciate all the help
Spec-Ops1
13
Mar 6, 2017 11:48 PM
99evoVI
Feb 1, 2016 04:53 AM
Gtizks
Dec 6, 2015 04:25 PM
tvor
Aug 20, 2015 02:10 PM
inslowoutfast
11
Mar 24, 2015 02:40 PM
