Leaking. pics
Old Mar 19, 2014 | 02:23 PM
600RR's Avatar
Leaking. pics
I have a leak on the driver's side. I've had it a while. Not sure what it is. Axle seal, TC, boot?
Old Mar 19, 2014 | 02:35 PM
EvoJoeIX's Avatar
What kind of fluid is it? You would know if its the axle boot, it would be thick grease flung everywhere, not fluid reside
Old Mar 19, 2014 | 02:49 PM
MikePL's Avatar
Check the actual axle seal. If it's wet, it's most likely that. I had mine changed because of a leak and was told it's fairly common. Looks like that's what it is.
Old Mar 19, 2014 | 03:43 PM
600RR's Avatar
Sorry mate, not good enough to know the fluid by it's smell.
Old Mar 19, 2014 | 04:59 PM
leemaster's Avatar
Veteran: Army
I would spray brake cleaner and get all that oil off, come check it the next day or two and you will find where it is leaking from.
Old Mar 19, 2014 | 06:54 PM
600RR's Avatar
strong first post lol
thanks, will do.
Old Mar 26, 2014 | 10:25 AM
ChargerX3's Avatar
looks like seal from here.
Old Mar 29, 2014 | 11:13 AM
black_beauty's Avatar
TC seal is my guess, I just replaced mine recently with a new clutch install...
Old Mar 29, 2014 | 01:41 PM
YGWolf27's Avatar
I'd say it's the Axle seal. Rotation as driving would throw it like that. My Civic had a torn seal that did it.
I'd go ahead and do what leemaster suggested though.
Old Mar 29, 2014 | 02:50 PM
barneyb's Avatar
On the five speed (idk about the 6 speed but probably the same), on the control tower, the bump on the transmission where the shifter goes in, there's a little round black rubber thingy. This is the vent for the transmission. it is pretty easy to knock this off when installing the transmission and it is above where you are seeing the leak. So, another possibility.
Old Apr 6, 2014 | 10:49 AM
dl100489's Avatar
cheak your axle seal or that plug known to leak
gsteensland
10
Jul 7, 2016 08:23 PM
woo9
Apr 29, 2015 12:36 AM
mateusz
May 18, 2014 09:58 AM
jdm-vr4
10
Apr 28, 2014 09:31 PM
sleepyghost
Sep 15, 2013 02:18 PM
