Turbosmart dual port BOV leak?
Old Sep 11, 2013 | 08:32 PM
sleepyghost's Avatar
Hey guys - If this has been covered in another thread I apologize.
I've got an issue with my Turbosmart dual port BOV on my 2006 Evo 9 MR. To make a long story short, its leaking, and its leaking from the piston. I had leaks from the recirculation ports, but solved that with new o-rings. While I was at it, I replaced all of the o-rings with the turbosmart o-ring kit. I should also note that this leak was present prior to replacing all of the o-rings. I've cleaned and re-oiled it with sewing machine oil as TS 'tech support' has instructed me to.
Here is my boost leak test setup:
When I actually broke down and called TS tech support, originally to attempt a warranty claim, within minutes of starting the conversation, it was clear that wasnt going to happen. After questions like "how are you boost leak testing" and "what do you mean, leaking?" - the gal I spoke to proceeds to tell me that "Its normal to see bubbles from the piston" after a long awkward pause, mostly from disbelief - I decided to quit while I was ahead.
I did the same test with my stock evo 9 bov, and does it leak? Yes. AT 22 PSI! this thing is leaking almost immediately, at <5psi. I've got a video of this thing leaking I'd be happy to post as well.
Has anyone else with this bov had this issue?
Old Sep 13, 2013 | 09:10 PM
iTzMe's Avatar
I've never heard of bubbles coming from a bov kinda weird take it to a performace shop and let us know what happens
Old Sep 14, 2013 | 11:55 AM
egis's Avatar
^^ he sprayed soapy water to see if it's leaking
Old Sep 15, 2013 | 01:51 PM
Thanks for clarifying. My question is has anyone else experienced this with this BOV?
Old Sep 15, 2013 | 02:18 PM
egis's Avatar
not at 5psi.your bov is faulty.
Ferp
Apr 5, 2017 09:41 PM
stunna2o1
Jan 25, 2016 07:02 PM
caduprado
Jul 12, 2015 04:15 PM
TJung
10
Jan 30, 2015 03:28 PM
free ride
10
Nov 11, 2012 04:20 PM
