Heat coming from vents?
have you guys noticed that when your A/C / air, is off, that heat still seems to come through them. The temp dial is at max heat but at idle no air comes through the vents because its off. When i get on the throttle i can feel the heat coming through the vents. I mean, having a heated steering wheel is great but is this normal?
Thanks.
Thanks.
If you turn the temp dial to Max AC and then keep the fan off, air won't blow through. Any other setting will let air through naturally through the vents, and the temp dial will control how hot/cold that air is.
I thought this was common knowledge in cars from the 80s, but hey it makes me feel smarter.
EVO8LTW
Feb 20, 2008 05:56 PM
highvoltz
Feb 2, 2005 07:08 AM
