Evo 9 mr burning oil
Old Apr 14, 2014 | 09:36 PM
Mrpayday34's Avatar
I just recently bought the evo a couple weeks ago it has 50k miles on it. It was leaking oil and burning it letting out a puff of blue smoke after shifting to 5th releasing the gas after high rpm. Figured it was the turbo so got the dealer to replace it with another stock turbo. Needless to say it's still doing it. Need some more opinions on what could be the cause or some where close by to take it. I live near Harrisburg, pa.
Old Apr 15, 2014 | 07:33 AM
bbong's Avatar
Do a compression test, look at the valves if there is oil on them (valve guides leak). If you're puffing blue smoke that is not a good sign, usually means you're burning oil in the cylinder and if the oil is not coming through valve guides, then it has to be rings.
Old Apr 15, 2014 | 10:58 AM
dtenev2's Avatar
Sometimes if a car is overheated or ran with bad/no oil, it burns the the valve guides, than it burns a lot of oil, especially on highway cruising, or high revving. I hope you didn't pay too much at the dealer for the new turbo.
Old Apr 15, 2014 | 11:44 PM
Mrpayday34's Avatar
Turbo
I didn't pay anything for the turbo. But I am doing compression test soon and seeing what's up but in the mean time I'm being easy on it. But in all honestly it might just be running rich it shoots a flame sometimes like backfires
Old Apr 16, 2014 | 10:51 AM
TreatsIX's Avatar
^^ let me know how that compression test goes.
My IX has 57k miles and has been doing what yours does for the past 7k.
Got really bad last week and did a compression test, 130,130,130,40 ;(
Old Apr 16, 2014 | 11:20 AM
grazzo77's Avatar
Check and make sure you PCV is working correctly and that you intake mani and TB are not covered with oil.
EV0lvedX
Aug 11, 2016 03:20 AM
febs1011
36
Feb 19, 2016 03:35 AM
Seifer780
Lancer Engine Tech
Sep 22, 2015 02:50 PM
febs1011
Sep 4, 2015 03:28 PM
Nofear23
Mar 3, 2015 05:50 AM
