TB Boost Leak Question
Old May 12, 2014 | 06:38 PM
Terror Rising's Avatar
I boost leak tested my car today and found a spot that is leaking. Unfortunately I can't really see back behind the throttle body to figure out where it is. From what I can see, hear, and feel it seems like it's coming from the circled portion of the attached picture. The noise changes audibly when I put my finger on this piece. What is this and can it actually leak or am I crazy?
Old May 12, 2014 | 06:49 PM
Evoryder's Avatar
change the oring and put a little high temp silicone sealant
Old May 12, 2014 | 06:51 PM
deylag's Avatar
Did you change the shaft seals? Those are known to leak.
Old May 12, 2014 | 06:59 PM
Shaft seals have already been changed. A little piece of the TPS side shaft was torn during install (2nd set to do this) so I was expecting the leak to be from the shaft. Instead it was coming from this part.
Old May 12, 2014 | 09:02 PM
slowsrt4:('s Avatar
change oring in there and it should fix it
steven5288
Aug 13, 2014 06:18 PM
jdm-vr4
10
Apr 28, 2014 09:31 PM
guyver858
Sep 16, 2013 06:39 AM
rartist
16
Sep 6, 2010 12:33 PM
delkat
13
Dec 27, 2009 08:28 PM
