A.C. Compressor broke off the block and i need help ASAP!
Old May 19, 2014 | 06:28 PM
eisnikesb's Avatar
Hello everyone so the other day i was driving and my power steering went out, so when i got home a took a look under the hood. I realized that my ac compressor broke off the block of my evo 8 which caused the serpentine belt to come off. I took it to a shop and had them take a look at it. My thinking was that i could just remove the ac compressor and lines all together and just use a smaller belt and just deal with no A.C. But the shop said that i need some sort of A.C. bypass bracket or valve to have the motor run properly, i cant remember fully what they said, but to me it seems fishy. So i need to know if i can just remove the ac components and just get a smaller belt and run the car with no negative affects to the motor without the A.C..
Thank you for any and all help.
Old May 19, 2014 | 07:05 PM
gsrboi80's Avatar
Yes you can!! Just need shorter belt. Check in the part number thread or search it you'll find the part number
Old May 19, 2014 | 07:14 PM
eisnikesb's Avatar
so all i need is a smaller belt nothing else correct
Old May 19, 2014 | 07:40 PM
AJCaron12's Avatar
http://www.streettunedmotorsports.co...moval_belt.htm
Old May 19, 2014 | 07:41 PM
AJCaron12's Avatar
If you are removing your A/C compressor, all you need is this belt ^
phrequenc
Aug 5, 2015 05:00 PM
Lancerzz
Sep 23, 2014 06:02 PM
eisnikesb
May 12, 2014 10:24 AM
kd5byb
Lancer Troubleshooting
Sep 7, 2013 05:44 AM
Bootys Evo
Jun 14, 2012 08:37 PM
