crap! suction pipe… :crap: (problem)
Old May 22, 2014 | 01:02 AM
wowzers's Avatar
Hi guys,
I purchased a suction pipe. (dunno what brand.)
its a 3" aluminium painted pipe, x2 sillicone hoses on each side… one for the air filter and the other for the turbo.
however, it only has x2 bungs!!!! (one for the BOV and the other the breather hose for crankcase) the rubber OEM hose has 3..
an extra small one thats about 4mm that joins to some electrical sensor under the MAF and I'm assuming the boost gauge?
should i post pics to explain?
i dunno how I'm gonna get a 4mm bung on… exhaust shops are hopeless here.
let me know your thoughts
thanks & regards,
Old May 22, 2014 | 05:40 AM
boostleak's Avatar
I think the third one is optional on some intake brands. My perrin intake also has three like the oem one. I just put a vacuum plug on small 4mm fitting since I don't use it.
Old May 23, 2014 | 01:11 AM
wowzers's Avatar
Hi there, are you sure?
So the Perrin has 3… a 1" for the BOV, 4mm for the solenoid and 8mm for the PCV hose.
how would you be blocking it off if you have all 3?
well the third one runs to some sort of solenoid. i didn't think it would be a good thing to block it off?
anyone else have aftermarket suction pipe kits?
Old May 23, 2014 | 05:37 AM
boostleak's Avatar
The third one is normally for the factory bcs. I run a grimspeed bcs so I don't use that line going to the bottom nipple on the intake. Do a quick search on here. there's plenty of info on this.
https://www.evolutionm.net/forums/ev...8-evo-9-a.html
https://www.evolutionm.net/forums/ec...t-vta-not.html
https://www.evolutionm.net/forums/ev...-question.html
Old May 24, 2014 | 04:42 AM
wowzers's Avatar
Hey, thanks for brining up those links.
So it seems majority of people just leave that hose out and vent it in the engine bay..using the new suction pipe without that bung / nipple.
My problem is that the OEM solenoid (BCS) has 2 ports … (one we were just talking about) and the other goes to the Actuator at the turbo.
i realised mine has been capped off… a mechanic that serviced the car prior to my purchase had capped off the line as it was running 28psi with no tune and supporting mods…
i might have to get my tuner to work out which one i can plug back in
cts4g63
14
Dec 30, 2015 01:49 PM
StreetThisEvo
22
Jul 23, 2012 03:48 AM
myersap93
Jan 22, 2012 08:21 PM
Evol X
Jun 17, 2010 07:18 AM
lancer03_Mike
Dec 6, 2003 09:05 PM
