Whole new setup, misfire on cylinder one. Need Help
Old Jun 2, 2014 | 01:28 PM
vxevolutionxv's Avatar
Ok, so where to begin... Build has been going on for a year and a half. Basically - Evo 9, brand new stroker motor, cams, FF setup, dual pumps , e85, running SD with tephra v7. On the first start it fired right up but with a mis on cyclinder one. Im getting a cam and crank senor malfunction code. Timing is dead on and the cam sensor is not 180 out. i just replaced the crank sensor cleared the codes and they came right back could it be the cam sensor/mivec cam sensor/or mivec oil control valve throwing the codes and causing the misfire. Also i try to idle the car up and after climbing about a couple hundred rpm the car dies out. Been tearing my hair out for the past week. Running outta patience about to set it on fire haha! Help would be much appreciated!
Thanks in advance
Old Jun 3, 2014 | 09:13 AM
Bump TTT
Old Jun 3, 2014 | 02:42 PM
CT9A PR's Avatar
tried coils?
xRoguex
Dec 6, 2021 07:58 AM
bwanner
Jun 17, 2014 06:19 PM
Alexl08
32
Dec 1, 2011 07:25 PM
Evilution23
37
Jun 6, 2011 10:15 PM
Arkitek
18
Jun 27, 2010 06:53 AM
