Evo needs a tune?
Old Jun 9, 2014 | 08:45 AM
Ironhide93's Avatar
Evo needs a tune?
Hi i recently got a 06 mr from a friend in VA, his car has a de-cat exhaust. This was done to it when he purchased it so he doesnt have any idea if the car was tune or not. Heres my problem, i live in NY and i had to put the cat back on to pass inspection, but i am not to sure if i have to get the car retune after putting back the cat on. Or would it be better to just resett the ECU.
Thanks guys, and I am pretty new to this.
Old Jun 9, 2014 | 08:52 AM
Biggiesacks's Avatar
Congrats on the purchase. Does the car have any other mods? If its just the cat you are changing, chances are it wont need a retune. You might be leaving a few hp on the table by not re-tuning it but nothing crazy. Resetting the ECU just clears volatile memory and does nothing to the tune.
Old Jun 9, 2014 | 09:00 AM
Ironhide93's Avatar
Thank you! I have to find the list he gave me ill post it up in a hour or two at work right now haha.
Old Jun 9, 2014 | 10:12 AM
slowsrt4:('s Avatar
do you have a check-engine light on?
Old Jun 10, 2014 | 09:06 AM
Ironhide93's Avatar
no doesnt have check engine light on. it does have a ecu boost controller tune with a gm3 port solenoid and a omni 4 bar map sensor
added to it
Old Jun 10, 2014 | 09:37 AM
aggieEVO's Avatar
If it has a 3-port, it had SOME tuning done. If you're unsure, you should look into it yourself or find a reputable Evo shop to check it out.
Old Jun 10, 2014 | 09:44 AM
jrainwater's Avatar
Do they do visual smog inspection in NY or just the plug in test?
Old Jun 10, 2014 | 11:14 AM
Ironhide93's Avatar
Thanks for the input guys, probably should take it into a shop and look at it.
Old Jun 10, 2014 | 11:19 AM
jrainwater's Avatar
Can you answer this question for me please? I have some good advice but I need to know if they look under your car in NY or if they just do a plug-in test. Trying to save you money vs taking it into a shop bro.
Old Jun 11, 2014 | 05:01 AM
Ironhide93's Avatar
they do plug it in for a onboard diagnostic and visual too they look under for a cat converter. The converter either has to be oem or CARB certified.
Old Jun 11, 2014 | 05:17 AM
shavkatjon2000's Avatar
IN NY we do Safety and Safety/Emission since the evo 7 8 9 is from 2003 to 2006 you will have to plug it in for the safety/emission test and it will scan then station computer decides to fail you or pass if everything the way it suppose to be you will pass and some shops do visual inspection some don't
Old Jun 11, 2014 | 07:15 AM
Ironhide93's Avatar
I guess the question is now if i put the cat back on with the check engine light go on. Knowing that it does have some kind of tune mainly for the boost might affect it? Guess i wont know til i get it put back on.
Old Jun 11, 2014 | 08:28 AM
jrainwater's Avatar
Sucks if they do visual, ok nvmd then.
Old Jun 11, 2014 | 09:05 AM
If you didnt have a CEL without it, you wont get one for just putting it back on.
Old Jun 12, 2014 | 02:18 PM
Ironhide93's Avatar
So the car has a de-cat megan racing exhaust, and I am planning to put a oem cat on it. Praying this would pass NYS emissions. Other wise i have to buy a stock exhaust to pass.
