New motor installed, minor issues
Old Jun 28, 2014 | 12:24 PM
VR4-EVO's Avatar
Finally got the Evo rolling again! Got a stage 1 block from DSM Graveyard and got it all back together. But I have one problem.
The car wants to die on idle. Mostly after it gets drivin around and gets warm. Also, since it might be related, I have what sounds like maybe a leaky Evo 9 BOV. It doesn't have the pronounced sound it did before. And lastly, the car is DEFINITELY running rich. Though it'll be about a week or so before I can get a tune. Can these issues be related?
And lastly, if anyone has any advice or tips or breaking in the new block and internals please share. I'm just taking it easy on her for the first 1k miles. I have conventional oil in it now and will switch to synthetic then.
Old Jun 28, 2014 | 03:24 PM
cfdfireman1's Avatar
http://www.mototuneusa.com/break_in_secrets.htm
Old Jun 28, 2014 | 03:34 PM
Biggiesacks's Avatar
Do you have logs? Have you done a boost leak test? Have you dialed in the BISS screw?
Old Jun 29, 2014 | 10:01 PM
VR4-EVO's Avatar
No logs (I don't have anyway to get them) boost leak test coming tomorrow, and I've adjusted the BISS screw to no avail. It idles rough, but will correct itself after probably 10 seconds or so. My gas mileage has also plummeted. Can the noise and bad mpg, and being rich all come from a boost leak?
Old Jun 29, 2014 | 10:15 PM
leemaster's Avatar
Veteran: Army
Hmmm.... check the iacv, something as stupid as that can cause said catastrophe.
Old Jun 30, 2014 | 04:25 PM
VR4-EVO's Avatar
It finally threw a cel and it was the p0121 code. So I guess im in the market for a new tps sensor!
Old Jul 7, 2014 | 04:15 PM
VR4-EVO's Avatar
UPDATE!!
So. Tps didn't help anything.
I've done some research, I'm getting 12mpg as opposed to the 26 I used to get. There's an extremely loud whistling sound that is completely in sync with the turbo. I did a boost leak test and couldn't get any pressure to build. Gonna try again tonight. And the car smells like unburt has if you're riding behind it. SUPER rich. Any more ideas?
Loud whistling is NOT normal. Sounds like a leak but I can't find it.
Could the wastegate be stuck open?
Old Jul 8, 2014 | 08:54 AM
newbieEVO8's Avatar
This may sound stupid but do you still have the EGR valve?
If so check to make sure your vac hoses are connected correctly.
yifuqiao
Oct 31, 2015 07:00 AM
08evo_x
Oct 2, 2014 07:38 PM
bigmoney890
33
Jun 25, 2014 01:22 PM
fireroasted
11
Apr 21, 2013 10:10 PM
smokedmustang
37
Sep 8, 2011 12:37 PM
