REXPEED air duct install
Old Jul 6, 2014 | 09:48 PM
supaduckie8113's Avatar
Does anyone have a installation guide on rexpeed air ducts for an evo 8/9? Im thinking about buying these but im not sure about the install procedure. Any help would be appreciated
Old Jul 7, 2014 | 05:57 AM
egis's Avatar
they come pre drilled.all you have to do is place the duct over that part of the bumper and using riveting tool install it.
Old Jul 7, 2014 | 01:02 PM
slowsrt4:('s Avatar
you need rivets and a rivet gun to install them, but there are holes for the rivets so just take them to a hardware store and they can hook you up with the right size river if you don't have them already. I think you will have to drill holes in your bumper too
Old Jul 7, 2014 | 04:06 PM
the drilling part is what threw me off, i dont have holes in my bumper and i dont know what the correct tool is to use to drill. Can anyone else chime in?
Old Jul 7, 2014 | 06:01 PM
egis's Avatar
rivets are included with duct.id say its crazy to drill perfectly good bumper.
Old Jul 7, 2014 | 06:37 PM
Evoryder's Avatar
drill? use a regular drill...you can use the double sided 3m tape, however, drilling is ideal. It will look prob off with the holes rivet-less
Old Jul 7, 2014 | 06:51 PM
superbovine's Avatar
just an fyi, the rivets are a not really sufficient in the long term as the bumper and carbon flex from heat/movement etc they get real loose. I used allen head stainless bolts once they were getting pretty questionable, looks much better now too.
Old Jul 7, 2014 | 07:57 PM
Turborico's Avatar
most importantly, you must not try to install them with the bumper on the car because you WILL drill into ic piping and/or couplings no matter how careful you're trying to be. after installing mine i wish i would have tried 3M double sided tape first to see how that turned out first before using rivets. oh and those ducts do have fitment issues as they are not perfect. you'll know this the moment you hold them in place on the bumper. im just glad i didn't destroy them before they were installed because they are fragile i believe.
Boost4ever
Aug 27, 2016 02:35 PM
EvokidIX
Nov 8, 2015 02:35 AM
Noize
Sep 2, 2012 09:44 PM
nothere
Aug 26, 2005 11:41 AM
erioshi
39
Jul 2, 2004 12:23 PM
