Oil light flicker
Old Jul 25, 2014 | 09:19 AM
KJS's Avatar
KJS
Oil light flicker
So I have the classic oil light flicker at idle. I bought a new OPS duralast PS123.
My car also has an Aem oil pressure gauge so I'm confused on where exactly the OPS is on the car.
Here are some pictures
First picture is what I see right next to the filter, second is what the hardline attachs to. Neither end looks like the end of the new OPS...
HELP PLEASE!
Attached Thumbnails Oil light flicker-forumrunner_20140725_121753.jpg   Oil light flicker-forumrunner_20140725_121813.jpg
Old Jul 25, 2014 | 09:37 AM
ekizenbe's Avatar
factory ops is on the back of the block i believe.
Old Jul 25, 2014 | 09:45 AM
foxbear2277's Avatar
Correct it is at the back of the block.
Under the intake manifold on the right hand side when facing the engine.
Old Jul 25, 2014 | 09:49 AM
Ev0ikon's Avatar
Yup. Right under the intake manifold.
Old Jul 25, 2014 | 10:11 AM
SilverShadow03's Avatar
Correct
Here is the part you'll be replacing. I think I picked this one up at O'Reily's...not positive.
Location (not my pic - off eBay):
Old Jul 25, 2014 | 10:34 AM
KJS's Avatar
KJS
Alright... I see it how do I get to it lol
Old Jul 25, 2014 | 10:51 AM
newbieEVO8's Avatar
very difficulty
But my better response is a question, are you sure you aren't losing oil somewhere?
Someone correct me if I am wrong but the oil light will also flicker if oil pressure is low and that could be a sign of a spun barring?
Old Jul 25, 2014 | 10:58 AM
WITH LONG ARMS! LOL
You'll more than likely need to remove the UICP to the TB, maybe the battery inless you have a mini battery..or possibly reach it from underneath the car.. Try getting at it from the passenger side too.
Old Jul 25, 2014 | 11:02 AM
It will flicker with low oil. Not sure about a spun bearing though. It will also flicker with normal oil pressure if the actual sending unit is dirty or going out.
I know because my oil light flickered for MONTHS .... if I was low on oil or truly running on low oil pressure then I would have seized my motor by now. Others have also experienced the oil light flicker with regular oil pressure and the unit I pictured above was simply old/clogged/going out and replacing it solved the problem.
Read through this thread. I think there are ideas to help you how to get to it.
https://www.evolutionm.net/forums/ev...d-problem.html
Old Jul 25, 2014 | 11:17 AM
sr20det91's Avatar
FWIW..on the evo 9's the OPS is on the filter housing. Just to eliminate any confusion.
Old Jul 25, 2014 | 01:20 PM
KJS's Avatar
KJS
I have an 05. Yeah I just changed the oil and pulled out 4.45 quarts and put back 4.5.
The car doesn't have low oil, so I'll have to try and get that new OPS in when I get a chance
Old Jul 26, 2014 | 01:59 PM
Trini Evo's Avatar
I just replaced mine for the same reason and problem solved. Only thing i removed was the strut bar. I stuck my hand down from the passenger side and removed it with a 27mm deep socket. Took me about 30 min.
Old Jul 26, 2014 | 02:05 PM
KJS's Avatar
KJS
Okay cool ill try that. Thanks buddy
Ev0la
Nov 3, 2016 07:15 PM
CaptainSquirts
Jul 5, 2016 07:43 PM
Royal Evo
Mar 17, 2016 11:57 AM
pd6186
Lancer Troubleshooting
12
Jan 19, 2016 09:45 AM
mitsumaster
Nov 14, 2015 07:55 AM
