evo 9 noise video
Old Jul 26, 2014 | 11:55 PM
ali911's Avatar
evo 9 noise video
Hi all, I keep getting weird noise when starting the car up. I found a video on youtube with the same noise I'm having.
Not sure what it could be but any help would be appreciate it
Old Jul 27, 2014 | 02:57 AM
wowzers's Avatar
Evo Engine Noise - YouTube
When was the timing belt last replaced?
If you had it changed within service intervals, was the timing belt tensioner replaced also?
Old Jul 27, 2014 | 11:27 AM
ali911's Avatar
I haven't replaced the timing belt or tensioner . the car has 48k
Old Mar 21, 2015 | 09:40 PM
ali911's Avatar
Bump anyone? Just got the car out from storage and i need to fix this problem
Old Mar 22, 2015 | 01:46 PM
Brandonm's Avatar
sounds like a belt. does the noise increase if you raise the rpm. my serpentine belt sounded pretty similar to that and i replaced it and fixed the issue.
Old Mar 22, 2015 | 06:20 PM
Bhsj13's Avatar
belt tension too tight imo. anyway, i hope your BOV isn't like the one in the video. it looks backwards.
Old Mar 23, 2015 | 07:14 PM
silverevo05's Avatar
I've been having the same problem. Re did everything and noise is still there. You can read here or another member on here as well
https://www.evolutionm.net/forums/ev...r-service.html
or
https://www.evolutionm.net/forums/ev...belt-swap.html
Old Mar 26, 2015 | 10:41 PM
butte's Avatar
My Evo 9 made a noise VERY similar to this (slightly longer intervals between the noise)
The balancer shaft tensioner pulley failed (had sprayed all of it's bearing lube around the area and didn't spin easily) and the belt had become pretty loose as well. I bought a timing belt kit and replaced everything, pulleys and belts, and the problem was resolved.
Old Jun 30, 2015 | 01:36 PM
^ might look into this
Bump for any info on the noise (this is not the normal IX timing belt noise that is fixed with bracket)
Old Jun 30, 2015 | 04:59 PM
barneyb's Avatar
Timing belt interval is 60K or 60 months. Now, I put on enough miles on my Evo to where time is never a factor. So, I don't have experience with the Evo being over on time. However, I found that my wife's WRX was overdue on time for a timing belt job and did one. Well, it was a good thing I did, I found some problems.
Old Jun 30, 2015 | 07:48 PM
BBYEvo82003's Avatar
Tensioner would be my guess
Old Feb 24, 2017 | 10:06 AM
any updates?
Old Feb 24, 2017 | 10:46 AM
ali911's Avatar
Originally Posted by silverevo05
any updates?
I had a loose part in there. it weren't my Timing belt. I will be changing my timing belt very soon
Old Feb 27, 2017 | 09:43 PM
What was loose??
JT-KGY
772
Jan 3, 2025 07:04 PM
kevzxvii
11
Sep 28, 2023 10:02 AM
kennemo
Aug 21, 2016 09:40 AM
Royal Evo
Mar 14, 2016 03:51 PM
Tommyy
Feb 20, 2016 04:28 PM
