Bad power steering rack, bad power steering pump or both?
Hey all, I'm hoping that someone who is more familiar with power steering systems can help me before I go ahead and swap out parts.
I have an 03 Evo 8 with around 116K.
Ever since I bought it at 85k there was some seepage around the power steering reservoir cap. I finally ordered a new cap and it was still seeping. I just had my first trackday after building the car and after my first session fluid blew out from the cap and went everywhere. (Cap was still on)
I thought that there may be air so I rebled it.
Towards the end of this session the car started to pull right.
After popping the good I found fluid again overflowed.
To be clear there are no leaks on the steering rack or ps pump.
Also the fluid in the reservoir is halfway up min fill.
Alignment on the car is perfect. Tie rods are good as well.
My opinion is that the regulator in the pump has failed so at high rpm the fluid pressure sky rockets. This is why it's blowing out at the cap.
I also think the rack is bad now since it's pulling the car to the right. Another issue is that a half turn away from full lock the wheel gets very hard to turn.
My diagnosis is that the pump and rack are toast.
Thank you in advance!
My feeling here is that you may be right about both parts being worn out. Yet since the PS pump is the quickest, cheapest and easiest to replace, I would start there.
If one of the reed valves in the pump becomes seized, then it could allow the fluid to begin to aerate, creating air bubbles. Think of it like when you mix a batch of pancake batter, using the whisk to put air into it, similar concept, creates more volume. Mix it with heat (more expansion), and you have a classic scenario for overflowing the reservoir.
Also, since you describe that your steering gets 'very' hard a half turn from the lock is a positive identification of a pump failure. Since the pump works the hardest towards the locks.
Your steering rack is puzzling to me and I have never heard or seen of a pump causing the rack to go all bananas like you describe. All it really is, is a ball on a worm gear with fluid pressure doing the work, so I'm lost on that one, sorry.
Yet it could be that pieces of your pump have found their way into the rack and are getting involved. Perhaps a simple flush of the system during pump replacement might clear that up.
Good luck OP.
Good luck OP.
Good luck OP.
Good luck OP.
Also just got it home on my trailer.
I drove it around the block and the steering wheel now must be at the 11 o'clock position to go straight.
I have a feeling the rack and pinion skipped on the rack and now it's off center.
I'm assuming that it could happen overtime.
I really appreciate your input.
So pump is bad.
Rack is fine!
Car was pulling because one of my tires jumped a belt!
Right now I'm contemplating getting the Buschur electric pump. I'll see what happens.
Thanks for the help!
Rack is fine!
Glad you got it figured out and the rack is fine. What PITA that would be to replace.
My friend has an S2000 and those have electric pumps, I couldn't tell the difference.
Plus, it's one less fluid to have and would help clean up the engine bay perhaps. Less rotating mass, so on and so forth.
If it doesn't fit I have an oem one coming as well!
Thanks for the help again
spyghost
Lancer How Tos / Installations
Apr 18, 2026 06:56 PM
Phalse
161
Nov 4, 2013 06:45 PM
MULLDOG
Mar 31, 2010 12:38 PM
redcat
Oct 11, 2009 04:13 AM
