P0340 code..no camshaft signal!
Old Aug 6, 2014 | 07:43 AM
babaz7's Avatar
i just installed a brand new 2.1l shortblock and after firing the car for first time it was sounding like it was misfiring, after that with help from evoscan i found out it was the p0340 code.
this is what it says... ''P0340 No Camshaft Signal at EFI ECU"
whats the meaning of this?
did i miss something when installing the engine, or some sensor maybe?
the coil on plugs also bacame hot.
i need your help please!
Old Aug 6, 2014 | 09:40 PM
babaz7's Avatar
bump
Old Aug 7, 2014 | 02:54 PM
slowsrt4:('s Avatar
maybe try flipping your camshaft position sensor.
Old Aug 7, 2014 | 03:16 PM
SilverShadow03's Avatar
+1
Camshaft Position Sensing Cylinder installation attached (1 page).
Old Aug 7, 2014 | 08:59 PM
babaz7's Avatar
the camshaft position sensor is in the right place, i think the cam sensor has gone bad, but also the car isnt getting any ignition in 1 or 2 cylinders.
if the cam angle sensor is bad, will the car still start?
is it possible if a ignition coil goes bad it causes the P0340 code to go off?
Old Aug 8, 2014 | 02:49 AM
babaz7's Avatar
i took out the cam angle sensor and it has a little oil on it, is this normal or there shouldnt be any oil?
Old Aug 10, 2014 | 12:19 AM
craig05evo's Avatar
Oil is ok on sensor, mine had some on it to. Im having a similar issue are you are, but its throwing the cams sensor and crank sensor at the same time. Strange issue i have is the car starts/runs/drives fine. I just redid the timing (im on a 2.4) and was hoping that would fix it but no such luck. I also swapped out a known good sensor from another car and my car wouldnt even start... However my sensor worked on a friends car... Im so confused by this.
fullm00nevo
Jul 20, 2015 10:19 AM
evilevo22
32
Apr 10, 2013 09:18 AM
OverBoostedEvo
Jan 21, 2013 02:45 PM
5LEEPERISAH23I
Oct 9, 2012 10:00 PM
Evo818
11
Aug 27, 2007 07:12 PM
