Oil return stock replacement?
Old Aug 11, 2014 | 04:57 PM
Jush's Avatar
Hi all
Hopefully just a quick question.
I'm in need of a stock replacement turbo oil return line.
Short story is: stock replacement manifolds arn't 100% the same as the cast stock (to be expected) and there a difference of about 3-5mm (0.11 - 0.19 inches for you Muricans) and is causing a leak at the pan. Rather than pad it out with more gaskits i'm looking for something like the STM line as a flexible alternative.
Would this be suitable for stock turbo/stock motor?
http://www.streettunedmotorsports.co...proclassic.htm
Cheers
Old Aug 11, 2014 | 05:58 PM
egis's Avatar
Map sell flanges $20 each.you can make your own using any oil friendly line way cheaper then $100 .or try to bend what you got .for example when I did evo 9 turbo swap on my E8 ,I re used stock oil return line.it needed a little massage but I got it.
manthny18
Jul 30, 2015 09:24 PM
AznSupraTT
Jul 1, 2015 01:04 PM
evo ippo
Jan 29, 2015 06:05 AM
MacMan
Feb 2, 2014 10:06 AM
