Front Case Install Help
Old Aug 23, 2014 | 05:13 PM
Evo_AK's Avatar
Veteran: Air Force
Can anyone give me a diagram to which bolts go where when installing the front case/oil pump assembly? Got a new case with new bolts and want to make sure I get it right!
Old Aug 23, 2014 | 05:22 PM
ak47po's Avatar
http://www.evoscan.com/vehicle-manuals
Old Aug 24, 2014 | 06:54 AM
Evo_AK's Avatar
Veteran: Air Force
Bump
Old Aug 24, 2014 | 08:27 AM
TommiM's Avatar
If your replacing with new bolts and you cant remember where they went then I would suggest searching around for pics of motors with the front cover pic installed so you can get an idea of where the bolts go. Just make sure you get all the bolts on there for the cover before you start putting on pulleys and accessories otherwise you may have to take them back off to get that one bolt on that you forgot.
If you cant find a good pic then just as you start putting things back together just make sure every actual bolt hole is being used.
Alchem1st
Apr 20, 2016 12:42 PM
thepoint4life23
16
Apr 13, 2016 01:23 PM
wvrx
Feb 4, 2016 07:31 AM
billybond_09
Aug 3, 2015 11:10 AM
iluvmydsm
May 5, 2011 06:05 PM
