Replace front case with motor in car?
Old Feb 1, 2016 | 06:47 PM
wvrx's Avatar
Pulled the head off my Evo for a build and have all the timing components removed right now - does anyone know if the front case can be removed with the motor in the car?
Hoping to install a stubby shaft with a new oil pump for peace of mind while I have everything apart.
Old Feb 1, 2016 | 07:23 PM
LetsGetThisDone's Avatar
Yea you can do it. Leave the balance shaft belt off the rear shaft if you're taking the front shaft out.
Old Feb 2, 2016 | 09:38 AM
wvrx's Avatar
Yep that's the plan. Thanks for the feedback - I was worried there wasn't enough space to slide the oil pump shaft out.
Old Feb 2, 2016 | 09:44 AM
With the cam side motor mount off, the motor will drop down and you'll have plenty of room. If you were really feeling froggy, there is enough room to remove the rear balance shaft and replace the bearings so that they're clocked to block the oil passages. But that's a lot of extra work that doesn't need doing.
Old Feb 2, 2016 | 07:53 PM
wvrx's Avatar
Perfect, that's what I was hoping to hear. If I don't end up replacing the front case/oil pump and only throw in a stubby shaft...I'm guessing I should replace the crank oil seal and the oil pump shaft seal? Is there a gasket for the front case too?
Appreciate your help man this will make my day in the garage go much smoother this weekend.
Old Feb 3, 2016 | 09:54 PM
There is a seal in the rear balance shaft, the oil pump seal, the front main seal (crank), the gasket for the front case to the block, silicone for where the case meets he oil pan, and the oil filter housing gasket. I think that's it.
Old Feb 3, 2016 | 11:10 PM
roni4g63's Avatar
just a question, even though it is great you want to do this, but if it's not leaking and giving you any trouble, why fix it? not talking about the rear main, that should be done since trans will be out.
Old Feb 4, 2016 | 07:31 AM
He wants to delete the balance shaft, and the head and timing components are already off, so most of the work is already done.
GetFoxed
Jun 12, 2019 04:56 PM
Rob_GPT
Nov 8, 2008 09:11 PM
Bloomie
Oct 21, 2007 08:14 PM
watchout
Oct 2, 2004 01:30 PM
AbusiveWombat
Feb 17, 2004 11:16 AM
